Question about RTO Automatic Transmission And Engine Oil Pressure Tester
P030 and P040 error codes 2000 odyssey - RTO Automatic Transmission And Engine Oil Pressure Tester
2000 toyata camery code p040 what needs to be done
No such code. Code should have 4 numbers.
Jul 28, 2015 | Cars & Trucks
I have a problem passing. Smog my car is a 2000 regal ls and the code is p040 any help !!!
From what I have been able to find, I would check your EGR (exhaust gas recirculation) valve. Since you are getting a code I would think it would be electronic. Older engines used vacuum ones.
Good luck
information found here
P0404 Exhaust Gas Recirculation Circuit Range Performance
Feb 27, 2015 | 2000 Buick Regal
WHAT DOES A 2003 HONDA CIVIC LX CODE P030 AND P040
You are missing a digit. P0300? P0740?
May 22, 2014 | 2005 Acura MDX
What will set a trouble code P040 ?
If the code is P0040, the common problem is the O2 sensor wires have been switched between the sensors on bank one and bank two.
Aug 29, 2013 | 2000 Buick LeSabre
Code p040
p040 is not a code you dropped a digit like p0400 or p0440 etc
Apr 05, 2012 | 2005 Ford Taurus
Codigo para radio de honda odyssey 2000
por favor necesito el codigo para el radio de mi toyota odyseey 2000 por favor marca error en el radio
Feb 19, 2011 | Car Audio & Video
Sensor 1 bank 1 sensor 1 P030 code from check engine light
I have an error P0430 on my '2005 Nissan Armada, how can I fix this without having to pay my mechanic approximately $1K for repairs on the catalytic converter?
Oct 14, 2010 | 2000 Chevrolet Cavalier
P0740 code showing in my 2000 Honda Odyssey
P0740 Torque Converter Clutch Circuit Malfunction
The problem could be the torque converter itself or the sensor circuit for the clutch.
Best to have a Transmission Expert look at it to see if any further damage has occurred.
Apr 19, 2009 | 1999 Honda Odyssey
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Vuk B
Bill Boyd
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
