Question about Refrigerators
Frigidaire FRS23H5ASB6 is freezing food in refrigerator section. Problem started suddenly. Ice maker not making ice
gwshaw71
  • 83 Answers
SOURCE: Freezer and Refrigerator section stopped working
check your drain line and check defrost system, defrost thermostat, heater, and timer
Posted on Nov 30, 2007
SOURCE: ice maker not making ice
my ice maker is not making ice what could be the problem, and there is not any water in the ice machine what do i need to look for
Posted on Jan 11, 2009
jonniewalker
  • 1029 Answers
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Posted on Mar 29, 2009
rylee_smith
  • 8619 Answers
SOURCE: Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2009
woodchuck789
  • 4059 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
Frigidaire FGHN2844LP ice freezing together. Replaced filter. Twenty hours later, ice maker not working, freezer warm, refrigerator temp. steady 40.
Hello Pat Havard,
I was pulling your owners manual to TRY to determine what could be done to block your freezer door or ice chute open during the filter changing process...
Today the ambient air temperature was at least 90 - 100°F
(degrees Fahrenheit)... To maintain 40°F your refrigerator
has to be working...
You need to look at your FREEZER side...
Your food, a pizza box... ice tray...
SOMETHING... in your immediate WORK area
is blocking vents... or proper closure...
Look at the door switch... make sure your light is OFF
My best guess... FILTER FIASCO induced.
http://www.appliancepartspros.com/frigidaire-ice-maker-243297606-ap5809314.html
The icemaker won't run unless you can freeze cubes...
Carnac the Magnificent
Jul 16, 2017 | Frigidaire Refrigerators
What causes ice maker to make constant clicking noise. This happens in the on and off positions.
The constant clicking noise is probably the neoprene gears within the timer motor itself. Well, sometimes there is a brass 'drive' gear that meshes with a neoprene gear which then in turn operates the mechanical components of the ice maker.
Aug 10, 2014 | Frigidaire Refrigerators
What casues the ice maker to make a constant clicking noise?
It thinks that ice has frozen into cubes, and it's trying to eject them. Look into the icemaker and move the sensor wires (stainless) around... you may get it to work right.
GE ice maker
If the freezer is cold enough to freeze food hard, look for a problem in the water line, water inlet solenoid valve, or possible ice build up on the ice maker itself that does not the allow the ice maker to complete it eject cycle and start a new ice making cycle.
Jul 14, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Continuous knocking noise from ice maker. Ice maker has been off for past 3 months. Only thing that will make it stop is turning it off or unplugging it.
Hi Marcel,
Thank you for contacting fixya.
Our ice maker recently had its water inlet freeze up, preventing water from filling the trays. The mechanism kept dutifully trying to push nonexistent ice cubes into a bin that never filled up, which might account for the knocking noise in your case.
To defrost it we just unplugged the unit, took all the food out of the freezer section, and left the door open for a couple of hours. It wasn't long enough for any of the frozen food to defrost, and since we were careful to minimize opening the refrigerator section's door, the food in that part stayed cold enough to be safe as well.
Feb 09, 2014 | Frigidaire FPHB2899LF
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Ge refrigeration model 20-25 icemaker not making ice
Fill ice maker with tap water and allow the water to freeze. If when the ice maker cycles and drops ice into ice bin it chooses not to refill with water at end of the cycle. That would point to the dual water control valve. If ice maker does nothing when filled with tap water that will indicate a defective ice maker. The model number you listed does not appear to be correct. Look around the fresh food section door frame and see what you have. This could be the ice maker or the dual water control valve causing this problem. Thanks Sea Breeze
Nov 16, 2012 | GE 20.3 cu. ft. Bottom Freezer...
The ice maker was making ice then some of the ice turned yellow and now the ice maker has stopped making ice. The freezer is still freezing the food in there.
The icemaker concists of a gearbox that has oil inside it.When the gearbox wears, it starts to leak at the shaft. Suggest you replace the icemaker.
Jun 22, 2010 | Frigidaire Refrigerators
The ice at the bottom of the bin for the automatic ice maker melts then freezes into a solid block. Is there a fix for this?
Good day,
If the machine both the freezer and fresh food section work totally normal, and the machine turns off and on as it normally has, then the problem usually lies with the water valve in the bottom back of the machine.
The ice maker, when it fills is designed to fill for a 7 second period of time. Many times, when the ice maker tells the valve to shut off, the valve due to wear, reacts slowly, and allows water to overflow the well of the ice maker, causing this problem. Very common problem.
Apr 08, 2010 | Frigidaire FRT18IS6CW Top Freezer...
Nov 30, 2007 | Maytag PTB2154G Top Freezer Refrigerator
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
