Question about Salton Jr. JM1 Juicer
How do I clean a juice wizard after use - Salton Jr. JM1 Juicer
How can I clean the residue from a Krups juice extractor--the white parts have an orangeish crust on them. (carrots)
Try washing the white parts of the juicer with lemon juice. That worked very well for me. There is a faint tint that remains, but not the orange coating.
Feb 10, 2011 | Krups Juice Extractor
The pulp is quite wet after juicing 2 cups juice. Can you pinpoint the reason?
Let it spin for a 2 or three minutes after juicing. You
can also, slowly, pour a little water down the chute to
leach out more juice and dilute it as well. Also hold
the basket up to the light to see if some of the holes
have become clogged and use a tooth brush to clear
them. If you're using the filters, just rely on the basket
alone, it's not that hard to clean.
Jan 26, 2011 | Acme 6001 Juice Extractor
How do I remove the grater/filter from juice collector to clean it? Also the juice collector from the drive shaft? Thanks
You have to lift off the juice collector (the black part around the grater)-you have to use a little force-then you'll be able to take out the grater.
Jan 10, 2011 | Maximatic EJX9700 Juicer
How to make orange juice from fresh oranges
Peel 4 medium size oranges and place in the juicer.
Juicing Tip: When juicing oranges (or any kind of citrus fruit) it is a good idea to juice the white membranes at the center of the orange. The majority of the bio-flavonoids in citrus fruits are found in the white membranes. Scrape off some of the white membranes inside the peel and include them in the juice. We don't recommend juicing the whole peel, this will produce a very sour unpleasant juice.
Nov 29, 2010 | Jack Lalanne Power Juicer 250 Watts
Cleaning after juicing
It's easy. Scoop out the pulp with your hand and
then under running warm water sponge the outside
first and mop up the inside next. Keep rotating the
basket as you clean. If the juicer becomes discolored
after a while, boil the parts in a solution of Oxi Clean
and water, then scrub. She will look like new.
Oct 02, 2010 | Acme 5001 Supreme Juicerator Juice...
Cannot remove juice bowl from Juiceman 410. Yesterday it was ok.
TRY INVERTING IT AND SOAKING IN A
SOLUTION OF OXI CLEAN AND HOT WATER.
Jun 28, 2009 | Juicers
Pulp galore!
are you exceeding the capacity of the juicer? you will get about 2 and 1/2 large glasses of juice before the pulp fills the spinning basket. Apple peels are very tough, apples and tomatoes need to be peeled before juicing. Use the filters, the juice comes out much clearer and the juicer is easier to clean up. I so a lot of carrots, carrots are super food.
Nov 21, 2008 | Acme 6001 Juice Extractor
Maximatic TS738 juicer
I just bought the same one and although I broke it, the cone just came off easily for me.  I just pulled it off and there were no clips or anything.  It goes in the middle of the top plastic part where all the leftover remnants go.  I used a tooth brush to clean it and that worked pretty good.  Any chance you may have the book so you could tell me whether I have a burned out belt?  I was overenthusiastic about what I was trying to juice and it was too dry.  thanks!
Sep 02, 2008 | Maximatic TS738 Juice Extractor
Rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
Jul 15, 2008 | Juicers
Stop running in the middle of juicing
well this is very common with this version, clean inside out, shredded fruits and veggies tend to stick and jam blades.
Jan 09, 2008 | Jack Lalanne Power Juicer (Stainless...
Salton Jr. JM1 Juicer Logo
46 people viewed this question
Top Salton Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Salton Juicer Expert? Answer questions, earn points and help others
