Question about Kitchen Ranges
Inglis range Turned on oven and ZAP swich done...part no. rac12-114-48 thermostat for oven for Inglis Range... can't find and need help please!
SOURCE: Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
Posted on Nov 25, 2008
  • 10865 Answers
SOURCE: viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Posted on Apr 30, 2009
SOURCE: Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
http://www.avantiproducts.com/
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Posted on May 05, 2009
brnspncr
  • 67 Answers
SOURCE: Viking professional Range Thermostat problem
Try www.retrevo.com/s/Viking-Range-VGIC305-4B-Ranges-review-manual/id/6768ag911/t/1-2/ . . .Good luck
Posted on Jul 30, 2009
fixyourboard
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
Why is the thermostat temp. range reading 30 degrees lower than it should be
Thermostat controls are nothing but variable resistors. Sometimes they build corrosion in the metal tab that it is sliding on. First try rotating the knob back and forth several times full range. If it is a slider instead of a knob, move it up and down full range. (This should be done on a regular basis.) If that does not work then shut the power off to the unit and get some contact cleaner. You can buy it in any electronic store. Spray the contact cleaner into the back of the control and work the knob full range again. It should feel easier to turn after a few turns. This should do the trick. If it doesn't, you need a new thermostat.
Feb 04, 2016 | Kitchen Ranges
Oven is Electrically charged Or Uses LPG domestic Gas?.
GS460 is not the full model number for the range. The range needs both electrical power (120V AC) and gas. The electric power is used for the burner igniter and controlling the range thermostat.
The GS460LEK can be used with either NG or LPG. It came with the NG orifices installed at the factory; a conversion kit needs to be installed to use LPG. (The cap in the regulator also needs to be turned 180 degrees to read LP.) This should be done by a trained installer. Most Whirlpool ranges will have the conversion kit attached on the back of the range near the regulator. See the installation guide from Whirlpool for your model, try https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=m3wLp9EUOpUUfCAXtvB5kw%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
The installation guide for the GS460LEKQ0 is available at https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%208522956.pdf .
I hope this helps.
Mar 28, 2012 | Whirlpool GS460 Gas Kitchen Range
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven trouble
I had this same problem with my range. It ended up being the thermostat that maintains the temperature in the range itself. This should help. The thermostat will usually have to be professionally replaced, it is too risky to be done by a novice so call a shop for help.
Dec 31, 2008 | Frigidaire FGF316 Gas Kitchen Range
Element burnt out
replace the swich for that burner.thats the one behind the knob.
Dec 02, 2008 | Hotpoint RB787 Electric Kitchen Range
Oct 24, 2008 | Kitchen Ranges
Inglis stove wont open oven door
Hello renald6969 ,
Welcome to fixya.
I'm Huuum and happy to assist you,
You aid, You had problems with your main board of my inglis and had to get it repaired by a dummy but you put it in and it shorted your oven door...now you don't know if there is a reset button to open it or if you have to bust it open to release contents inside!
STOP
Try this reset feature and see if I can help you open it.
1.Turn everything of on the range and oven.
2.Go to the breaker and turn it off for 5 minutes.
3. Turn the breaker on.
Now lets see if this procedure reset the system and released the oven door lock!
Let me know!
Do not break it open!
I'm here tonight .
Just let me know!
What is the model number and
How old is this electric range?
I am Huuum
Please do not forget to leave a rating before you sign of!
Sep 23, 2008 | Kitchen Ranges
Self cleaning oven
Press the cleaning button and then the up arrow that regulates the temp as if you are baking I think it reads 300 and then it starts. This is for Kenmore self cleaning
Dec 10, 2007 | Magic Chef CER1115AA Electric Kitchen...
Kitchen Ranges Logo
71 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
