Question about Daewoo DTQ-27S3FC 27" TV
Popping sounds I have a Daewoo tv, it's about 4 years old. It worked except it had a very very slight problem. The screen would pop (get a tiny bit bigger -only my wife noticed it) for a split second every 45 seconds. Now the sound and the screen both pop (the sounds cuts out) for less than a second but it's still annoying. Is there anything i can do? I hit it and it went away for a while but it keep coming back.
How do I get rid of those horizonal lines on my Daewoo TV?
Posted on Jan 04, 2011
  • 3 Answers
Loose connections or cold solder can cause this problem. Try to resolder all connections in the sound and video sections. Especially the video jungle IC section where the sound and video (IF) can be found. Good luck!
Posted on Sep 26, 2007
    Genius:
  • 1,694 Answers
Do a complete overhaul of the regulated power supply===solder any/all bad connects,replace any weak capacitors.HB Electronics kit #103-088 will help you locate which parts go bad===get on it before it crashes hard!
My Model # F36669, about a 5 year old 36 inch (non flat screen) RCA T.V. is popping loudly in back and turning off. I looked in back and noticed the popping noise is a short or something that is causing an...
That my friend is the high voltage transformer with a tiny pin hole allowing the high voltage to arc to ground. The red wire going to the picture tube is carrying 30 thousand volts to the anode connection on the CRT. This is not a consumer replaceable part as the CRT can retain healty voltages even when off. Refer to a local TV technician.
Aug 14, 2009 | Televison & Video
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Toshiba HD made a popping sound and went out.
Check the lamp to see if it popped. Try replacing it. Also check the web for class action law suit for these sets, Toshiba has an extended warranty for lamps for certain units.
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
Popping sound with picture
try getting a cleaning kit from radio shack for 15 bux the lens maybe dirty
Jan 21, 2009 | Haier TN201AUV 20" TV
Hitachi 50V720 Rear Projection TV
Good Day, douganddawnc;
What ever is popping is locking up the CPU circuit. Call a Factory Authorized Service Center Have figure out what is popping, get an estimate first. Good Luck, big IRISH.
Aug 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
F36650
Bad flyback transformer = 257805 or Asti 2078..........T.
Please rate this solution.................
Nov 05, 2007 | RCA F36650 36" TV
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
KDF60WF655 Popping, Cracking, Squeaking sounds?
the outer screen case screws need to be tightened.
Feb 24, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Poping sound, white specks and what looks like sparks
Possible arcing CRT or possible arcing IHVT part # 239111.
Dec 29, 2006 | Proscan PS50700 50" Rear Projection...
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
See all Daewoo DTQ-27S3FC 27" TV Questions
Daewoo DTQ-27S3FC 27" TV Logo
59 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
