Question about GPS
Navigon 70/71 premium - GPS
I have a Navigon 40 Premium that will no longer charge
Its either the battery, the connection where charge is connected or the source for voltage.
If you use a cigarette lighter plug there is also a fuse inside that(since I do not know how you charge I suggest that)
Dec 21, 2012 | GPS
Fs201
I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
Apr 10, 2012 | Navigon 2100 Portable GPS Receiver
I turn it on now it says navigon software cannot be started hold on off key pressed and press reset simultaneously..still doesnt work...help!!!!!!!!!!!!!!
Delete the app and reinstall it via iTunes.
If that doesn't work, you might want to consider restoring your iPhone via iTunes, then reinstalling Navigon. Hope that helps.
Regards,
-K
Jan 13, 2011 | NAVIGON AG NAVIGON MobileNavigator North...
I have a Navigon 2100Max 4.3" GPS. When it turns on freeze at the Navigon screen. I tried to reset it won't work. Their website is no help. Please help.
Please remove the battery for a minute or so. If the problem still persists then have the firmware reinstalled as it has got corrupted.
Dec 14, 2010 | GPS
Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
May 08, 2010 | Navigon 2100 Portable GPS Receiver
Want to install xcsoar on a navigon 4310 pna. put the xcsoar program on a micro sd card, can't get it to work.
Hi Mart136,
Were you able to get XCSoar to work on your Navigon 4310? I have the same problem with XCSoar and my Navigon 2100 Max. I did exactly as prescribed for installation on the XCSoar site but my 2100 Max keeps asking for the Navigon SD card .. it doesn't want to recognize a standard SD card.
Does anybody have any suggestions? Thx Much!
Oct 04, 2009 | Navigon 2100 Max Portable GPS System
User manual for navigon 1200.
Here's a link for the user guide..
http://www.navigon.com/site/uk/en/products/car_navigation/navigon1200
scroll down, on the righthand side you will see where to download it. If this helps you plz rate this. Thank you kindly.
Jan 30, 2009 | Navigon 2100 Portable GPS Receiver
NAVIGON 2100 won't move as I go down the road.
garyboop1 Try just rubbing you finger accross the screen, it should give you some result. Rusty1
Dec 31, 2008 | Navigon 2100 Portable GPS Receiver
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
GPS Logo
149 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
