Question about Electrolux Washing Machines
Ewf 168540 w
E20
3 Suggested Answers
  • 15 Answers
SOURCE: electrolux EWF 1470 Error code E20
could be the element at fault or pressure chamber
Posted on Jan 12, 2010
ZJLimited
  • 17970 Answers
SOURCE: wat is code for e20
E20 error code measn blocked filter. Removing the blocked filter you have to remove the water from inside by using the small flexible tube which located next to the filter at the right bottom of the machine. Then the only think it still remains was to unscrew and clear the filter.
Hope helps.
Posted on Apr 22, 2011
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Feb 21, 2015 | Electrolux Washing Machines
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Hi i have an electrolux ewf 1087 that wont start everytime i press start it goes straight to drain, like from 2 hrs, it will go down to drain for 2 seconds then down to 0, if you turn it off then on again...
Here are two reset procedures for the control panel that might get your machine working again:
  1. Unplug the machine for about 1 minute. Plug it back in and check the machine's operation. If this doesn't work, try the next reset procedure.
or
  1. Turn the dial to Off.
  2. Press and hold the start/pause button and the nearest option button. While holding them down, turn the dial one notch clockwise.
  3. The machine will beep or flash, when it does let go of the buttons.
  4. After you release the buttons, turn the dial slowly, stopping at each click until you get to "off".
  5. Now, turn the dial to any setting, then turn to off.
  6. Check the machine's operation.
Jun 18, 2011 | Electrolux Washing Machines
Wat is code for e20 on a ewf 1080
Hope helps.
Apr 22, 2011 | Electrolux Washing Machines
Looking for drivers for snapscan e20
You can can get the driver for your agfa snapscan e20 at http://www.downloadatoz.com/driver/download_30864,agfa-snapscan-e20-driver-scanwise-2-0-0-9-e20-windows.html
Dec 27, 2010 | Agfa SnapScan E20 Flatbed Scanner
I have an EWF 1090. It was washing normally. I went to check on it and the code E20 was showong. I opened the drum filter and emptied some debris out. I then went to turn the machine back on and there...
I have a similar problem on mine. We suffered a few E20 codes on the preceeding days before the machine went "dead." I assumed an issue with one of the pumps had caused the computer to get cooked. The problem is that I can't find an electrical data sheet inside the machine anywhere. I've been trying to find a service manual online with no luck so far.
Jul 03, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Hi , I have an elctrolux washing machine, and it stops half way through the cycle 'saying' E20. Does anyone know waht I have to do Thanks RN
E20 is difficulties in draining for washing. which can be drain tube kinked or blocked, drain filter clogged or dirty or the pump impeller behind filter is getting jammed by a coin or cotton or anything wrapped around it, remove filter and look at back of hole and see if impeller will turn use a long screwdriver to turn it, obviously with the power off
May 25, 2010 | Electrolux EW1000i Front Load Washer
How can I reset my electrolux washing machine afer an E20 error?
turn the dial to off. Press and hold the start pause and the nearest option button. While you're holding them down, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons. Release the buttons, then turn the dial slowly, stopping at each click until you get to "off". Now, turn to any setting, then turn to off.
Now, try the machine. If it works, I'm very happy. If not, perhaps someone else can help.
Good Luck
Apr 20, 2010 | Electrolux Washing Machines
Electrolux EWF 1470 Error code E20
Jan 12, 2010 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
