Question about Novoflex Qpc Platform Base With Center Column
I purchase at Tony Little Gazelle Glider in 1996 and I have enjoyed it but the foot platform has broken several times and replaced by Airofit platforms now I am trying to get 2 because one just broke and the other is that I don't want to miss my work out. Please help me in this matter Janis Bailey, 25 tuxill Ave, Corning, NY.14830-phone607-962-2314 This is a product description of last order n5853 FT PLTFRMS, THANK YOU MY EMAIL jbailey@cppmail.com please let me hear from you
Need gazelle edge spare parts
Fixya does not sell gazelle edge spare parts.
Sep 11, 2017 | Cars & Trucks
I just purchased a glider model #DA6452R-DC and the back of the glider was not in the box how do i get one?
one might think thru the place purchased would be the starting point .never heard of a TV called a glider .
Mar 12, 2017 | Televison & Video
Need prices for parts to gazelle freestyle elite
Try to contact their Fitness Quest customer support for the prices of the gazelle freestyle. Their number is 1-800-321-9236. You can order and pay for replacement parts with a credit card over the phone. The customer service center hours are Monday through Friday, excluding holidays, 8:30 a.m. to 6 p.m., Eastern Time. Have the model name of your Gazelle Glider, as well as information about the problem and the part that is broken.
Apr 23, 2016 | Baby Gear
How can get replacement parts for swivel glider recliner?
sadly we have no idea if you can buy them from the manufacturer or not .
Apr 16, 2016 | Cars & Trucks
Where can I get an electronic monitor replacement for the gazelle freestyle elite??
If your machine is not under warranty or you have questions about a replacement part, contact Fitness Quest customer support at 1-800-321-9236. You can order and pay for replacement parts with a credit card over the phone. The customer service center hours are Monday through Friday, excluding holidays, 8:30 a.m. to 6 p.m., Eastern Time. Have the model name of your Gazelle Glider, as well as information about the problem and the part that is broken.
Email Your last option for contacting Fitness Quest for Gazelle Glider replacement parts is to email the customer service department. Email customer service directly (customersupport@fitnessquest.com) or complete an online form on the Fitness Quest website. The form asks for your name, email address and provides a section for you to write in your question or request. The website says a customer service representative will respond within one to three business days.
Dec 01, 2014 | Cars & Trucks
Tony little gazelle freestyle elite replacement parts
I found something on amazon, here Amazon com gazelle freestyle parts. I hope this was helpful. cheers
Jul 18, 2012 | Exercise & Fitness
Have a Little Tikes Endless Adventures Mountain Climber. The brown platform has cracked and has a hole in it now. I would like to replace this part.
Regards, Tony
May 17, 2011 | Little Tikes Endless Adventures Look Out...
WHERE CAN I GET A MANUAL FOR THE GAZELLE FREESTYLE
On these units trace the wire going to the frame there is a sensor and on the movable frame their should be a magnet check the proximity of the sensor to the magnet ( should be about 1/8" clearance ). Now if you have the same problem, then you can test this sensor by using a multi meter on continuity setting follow the black connector to the upper board disconnect it and place leads on to connector MAKE SURE you have a good connection when testing. Have someone get on the unit and start using it, the back and forth action should open and close sensor circuit if not replace sensor if operating the the upper console is defective and that needs replacing . Call them @ 800-780-6744 they should be able to help with parts and a manual.
h
May 26, 2010 | Exercise & Fitness
1996 chevy tahoe 4wd LT 4Door 5.7L Vortec. Truck will not start, the starter grinds VERY loudly. Replaced starter several times, battery is good, replaced crank position sensor. Possible pre ignition? ...
i suggest removing the flywheel inspection cover, and rolling the engine over a little bit at a time, checking to make sure that there are no worn or broken teeth. also, make sure there is no lateral movement, which could indicate a broken flexplate. good luck.
Dec 08, 2009 | 1996 Chevrolet Tahoe
Tony Little Gazelle Platinum plus
Broke rear swing cable. Need replacement parts. Does anyone know of any web site where I can order only replacement parts?
Oct 26, 2009 | Exercise & Fitness
Novoflex Qpc Platform Base With Center Column Logo
46 people viewed this question
Top Novoflex Photography Experts
Tony
Are you a Novoflex Photography Expert? Answer questions, earn points and help others
