Question about Dell OptiPlex GX200 PC Desktop
My Desktop says Cover was previously removed, Strike F1 to continue or F2 to run setup utility. When I strike any of the two keys, nothing happens.
5 Suggested Answers
SOURCE: strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Posted on Dec 24, 2009
computus
  • 487 Answers
SOURCE: I had my battery run out, when I changed I get a
Hi, you will need to perform a windows restore using your windows CD. Insert CD in drive and select the appropriate option. You will not loose any of your work doing this.
Posted on Jul 30, 2010
SOURCE: My Desktop Dell Optiplex GX200 computer says
optipaxGX400 noboot itsayse insert passworde
Posted on Sep 14, 2010
  • 68 Answers
SOURCE: "Floppy Diskette seek Failure Strike F1 key to
maybe the floppy disk drive is defective or maybe the IDE cable is deffective, or maybe the cable on the floppy drive is not properly inserted , try to replace IDE cable of the floppy drive if still the symptoms happens replace the floppy drive
Posted on Jul 20, 2011
Jul 20, 2011 | Dell OptiPlex GX520n PC Desktop
Heloo sir i have a problem with my dell 170l when i start it it shows ''strike F1 to continue, F2 to run the setup utility'' when i click f1 it show ''f1 to retry boot,f2 for setup utility'' plz help me...
Hit F2,look in setup to see if the hard drive is recognized and check that the date and time are correct.
Then hit esc key. it will ask if you want to save changes, click yes. It should boot and probably ask you to hit F1 or F2 again., unless there is a problem with the CMOS battery, which may need to be replaced.
If you hit F1 to continue, it will boot, but your time and date will be off.
Dec 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I had my battery run out, when I changed I get a message that says Strike F1 key to continue, F2 to run the setup utility. When I strike F1 nothing happens, when I strike F2 I enter the bios and I change...
Jul 30, 2010 | Dell Computers & Internet
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
I've installed a new hard drive and put in more RAM on my Desktop. Now i get this message WHAT DO I DO. The amount of system memory has changed. Primary hard disk drive 1 not found Strike the F1 key to...
Strike F2 to go to the bios to run the setup utility
Don't touch anything , save and reboot
If primary hard disk still not found
reboot press F2 to re-enter the bios
Look for Auto Detect Hard Disks
if the computer shows a hard drive is detected
set the drive to LBA if possible
save and reboot
Az.
Sep 15, 2008 | Computers & Internet
Dimension 3100 Won't Boot
Make sure your HD Cables are all firmly plugged in, and that all drives are starting when you turn on the computer. You can tell with harddrives as they will slightly whine, and have a small, steady vibration to them. If they are all starting, and all cables are fully seated, check in your Setup utility that the drives themselves are Auto-Detect. If none of this fixes your issue, you may have to refer your computer to a computer repair shop.
Hope this helps!
-Backu
Jan 16, 2008 | Dell Dimension 3100 PC Desktop
Dell OptiPlex GX200 PC Desktop Logo
13 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
