Riso cz 100 displaying error code p-15-128 - Office Equipment & Supplies
  • 22 Answers
SOURCE: Have riso cr1610 - prints for few copies, stops,
Ink overflow.. On each end of the drum there is adjustments that can be made to the squeege. This is what scrapes the ink through the screen. These scrapers may be applying too much ink or internally too much ink is in the drum. These scrapers can be adjusted from each end. If you have a hard time getting the copy dark enough try to increase the flow of ink through.. this will take away the ink inside quicker. Another problem could be cheap aftermarket ink. I noticed i had a problem with one supplier that the ink was so thin it actually drips out of the drum when not in use.. The only other solution is to adjust the drum internally if the problem persists. This means removal of the drum to adjust ink flow.. This shouldn't be the problem..
Posted on Aug 11, 2009
  • 22 Answers
SOURCE: RISO RZ200
D22-542 is saying that there's a problem with the printed circuit board on the print drum. It's not communicating with the machine. D04 -534 says that the incorrect ink cartridge is installed. First, is this a new drum you are introducing into the machine? if it is, not all drums are interchangeable. You need to get the right pcb (printed circuit board) for the ink drum you are using to match your machine. Second.. Something is mismatched here with the ink cartridges. The only way you'd get the ink cartridge error is if the drum is in the machine. I had this problem with a Rn 2130 ui.. I bought a used drum off e-bay and it wouldn't work. When I stole the pcb from another color drum it worked fine. If you have been using this drum in this machine before... be sure that the connection between the drum and the machine is good. Make sure you have the right ink cartridge too. Some of these aftermarked re-sellers sell stuff that doesn't line up with the tabs on the inside.. I've got some ink here that if you hold your toungue just right and turn the tube about 2 degrees it'l work.
Posted on Aug 14, 2009
  • 747 Answers
SOURCE: Riso RA 4050 displaying error code E 57. What is
papper jam.
Posted on Feb 15, 2011
SOURCE: Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Posted on May 30, 2013
  • 5 Answers
SOURCE: How can I fix an error code 'c01-563' on Riso RZ370
Changing the ink tube or the RFID chip on the ink tube may solve your problem.
PrntNow.com
Posted on May 31, 2013
Riso cz 100 showing paper jam error J08
Take it apart and check to see that no paper not even a sliver is in the area of the sensor.
Nov 16, 2016 | Office Equipment & Supplies
Check setting error in d-04-560 Riso CZ 180
saya membutuhkan informasi dimana di surabaya service mesin cetak riso black cz 180 ?
Feb 04, 2014 | Office Equipment & Supplies
Error code J04 for riso cz180
riso cz -180 mechine
problem :- code eror :- P02-400
Mar 02, 2013 | Office Equipment & Supplies
Cz -180 Error Code P98-934
RISO CZ -180Model
Problem :- P04-513
Feb 21, 2013 | Riso RZ220 Duplicator
Riso- RZ220 codigo de error 18-531, el cilindro no se puede sacar .
The error code should start with a letter. Is it 'P'?
Error P18-531 means: Print drum lock is still ON even after 100 milliseconds after the print drum lock solenoid is activated.
Check te solenoid! Maybe it is defective or only stuck.
Mar 01, 2011 | Riso RZ220 Duplicator
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
56 people viewed this question
k24674
