Question about Intel Motherboard
Dq965gf red and green light always on - Intel Motherboard
2 Suggested Answers
babes_ganda0
  • 381 Answers
SOURCE: I have a red light color behind the green light color
hi..the indicator lights is meaning the board is found a shorted or not working parts.if u want find as fast remove all the IDE from the board and remove the memory and VGA if you have then clean the memory using paper eraser all the pin connectors then try to put it back the boot the board/power..good luck
Posted on Jun 15, 2009
Green light blinking, red always open
The chroma Is should be suspected. The set need a through check.
Apr 15, 2012 | Toshiba 44NHM84 44" TV
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
I have had problems connecting to internet all weekend (internet - red light), am on now but internet and ethernet green light keep blinking, is this ok.
No because dsl light should be solid green light. You need to contact your ISP to check if there is a problem on the network.
Jul 11, 2010 | Computers & Internet
Cannot open the disk and cannot read the disk as well. The green light at the center of the ring always blinking
Hello
If you only get a flashing green light on the center while you turn on the console. You should get a green light going in a circle around the center light, (the 4 other lights, that can turn red as well (famous Red Ring of death))
if you don't get any red or green lights around the flashing center ring, then the console is not able to turn on / boot up properly and is in need of repairs, check the powersupply led, what color is it? it should be green when you power on and orange when not in use.
Jun 08, 2010 | Microsoft Xbox 360 Console
Heath-zenith sl-6107 wiring diagram
hi there the wirings colour codes for nz are as follows
OLD WIRING CODE
Green = Earth
Black = Neutral
Red = Phase Or Live
NEW WIRING CODE
Green/Yellow = Earth
Blue = Neutral
Brown = Phase or Live
============DANGER 230VOLT ===============
Electricity can kill.
You should use an Electrical contractor for this repair job,
Caution always turn off power first before touching any wiring,
The Live wires always carry power,from one point to another,
the black neutral is your return path from the live phase wire
the green wire is always the ground ,
In this example
the sensor will have four wires as follows
Green = Earth Wire
Black = Neutral
Brown = Phase (incoming supply) 24 hrs
Red = Phase Load (outgoing supply) from sensor to lights triggered
Notice there are to phases in the circuit.Brown and Red
Always treat them as LIVE or Active Power.
Brown will normally be the Live incoming power and
Red will be the load side of the sensor,
Check the brochure supplied by manufactuers or their website to confirm the wiring order is correct before commencing any installs or repairs,
Always Safety first.
Safe a live today and you'll remembered forever.
Jul 06, 2009 | Heath Zenith Occupancy Motion Sensor Wall...
I have a red light color behind the green light color in my board.What did this mean? The board number is DQ965GF
Jun 15, 2009 | Intel Motherboard
Internet Light Stays Red on WAG54GS Wireless Router
If your router's internet light is red it means to say that there's no connection. You really have to call Tesco.
Aug 21, 2008 | Linksys (WRT54GC) Router
Need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Feb 09, 2008 | Car Audio & Video
PS2 Power Cable
This is normal just press the button that is red and it will work like normal again! you will have to always do that because that is off because there is two ways to turn it off at the back and holding the green light till it turns red
Hope this helps - Josh Howard
Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
Intel Motherboard Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
