Question about Jacuzzi MAGNUM FORCE POOL PUMP 2 HP 115230V 94027120
The pump wont prime - Jacuzzi MAGNUM FORCE POOL PUMP 2 HP 115230V 94027120
FUEL PUMP WONT PRIME?
If nothing else comes on such as lights or anything, I would suspect the main fuse is blown.
Jun 12, 2014 | 2002 Suzuki GSX-R 1000
12ht wont prime
filling the filters before installing will make priming go more quickly.
once the pump is primed crack open the fuse line at the injector while cranking until you have fuel pulsing out, close it then move on to the next injector.
keep doing this until the engine runs smoothly.
it may start running before all the injectors have been purged so keep clear of all moving parts and a fire extinguisher handy would be a good idea.
Apr 14, 2013 | 1989 Toyota Land Cruiser
2006 monte carlo wont start without priming
sounds like your fuel pump weak, need to check fuel pressure when engine won;t start and check with engine running
Sep 03, 2012 | 2006 Chevrolet Monte Carlo
Wont pump water in or out cleaned nozzle still wont pump any water
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101';';
Jun 20, 2011 | Keurig Platinum B70 Coffee Maker
Wont start unless manually primed
Turn the ignition key to the ON position without starting the engine
You should hear the fuel pump priming for about a few seconds then shutting itself off.
If not hear replace the engine oil pressure switch
The 3rd wire to that switch is the pumps prime switch lead.
When the engines oil pressure is reached the computer will shut that circuit off and turn on the fuel pump relay
If you hear the pump prime the relay maybe at fault instead
Jan 19, 2011 | Chevrolet 1500 Cars & Trucks
ZXR750H2 1991 FUEL PUMP WONT PRIME
jump the pump run a hotlead to pump
Jul 05, 2010 | 1990 kawasaki ZXR 750
It wont hold its prime , changed out the foot valve and still wont hold its prime
If it's not leaking back through the foot valve, then it must be leaking out someplace else upstream of the pump. It's remotely possible that it's siphoning off from the draw downstream of the pump (if that is significantly lower in elevation than the pump) - but I don't think that could happen unless you had air leaking into it someplace. Just food for thought. I don't know the ups and downs of your piping.
May 21, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
1999 dodge diesel 3500 transfer pump runs properly but wont pump fuel even sticking line in jerry can
most pumps wont pump until they have been primed,some pumps do something called "cavitate" or another term is "vapor lock"so try cracking the out going line,priming the pump with a little fuel in the incoming line and then placing it into the external container.when you get fuel coming from the outgoing line then you can cinch up the outgoing fittings.
Oct 12, 2009 | 2004 Dodge Ram 2500
Could this be a cold start problem
defective fuel pump the check valve is allowing it to lose prime replace fuel pump.
May 28, 2009 | 1996 Chevrolet Blazer
I have a flotec water pump that sits on top of my pressure tank, pump worked ok last season, and when we tried to prime the pump to start this season, it wont pull water up from the well pipe, pump will...
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Apr 06, 2009 | Flotec Corrosion Resistant Shallow Well...
Jacuzzi MAGNUM FORCE POOL PUMP  2 HP 115230V  94027120 Logo
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
