Question about GRACO INC Paint Sprayer. ProX7 Airless Paint Sprayer 261815
Paint sprayer leaking out bottom. Paint all inside casing. What is leaking?
  • 50 Answers
This is a semi-professional piston pump airless paint sprayer. Inside the paint pump there are 2 sets of packings, one set seals the piston where it comes out of the pump (the top) where you put a drop of TSL (throat seal lube) to lube them each day you spray; the other set is inside the pump cylinder where they are lubed by the paint or water. When the packings wear (because paint is abrasive), the paint starts to leak out at this point, then it can fill the TSL cup and overflow. The sprayer needs a regular service to change the packings and maybe the piston rod if it is scored, otherwise a damaged rod will wear out the new packings fast.
Posted on Jan 03, 2015
Same thing happening
Posted on Apr 01, 2014
Where can I find a schematic for the Krause & Becker paint sprayer? Mine is no longer working, and I noticed a disconnected set of wires hanging out the bottom of the pump casing.
[PDF]Airless Paint Sprayer - Harbor Freight Tools
manuals.harborfreight.com/manuals/68000-68999/68001.pdf
Airless Paint Sprayer. Item 68001. Read this material before using this product. Failure to do so can result in serious injury. SAve thIS mAnuAl. Notice.
Sep 26, 2015 | Tools & Hardware - Others
Can you paint gourds which are not dry inside
You can only paint gourds when it is dry inside.
Use acrylic paint and it dries very fast. Click:
Reeves Complete Acrylic Painting Set
Jan 12, 2015 | Tools & Hardware - Others
My sink sprayer stopped woking (no water goes to it and nothing is leaking
Debris has come through the water supply and clogged the sprayer, remove debris and test sprayer
Sep 01, 2014 | Niagara Commercial Kitchen Pre-Rinse Sink...
My 640 titan run but will not prime it does not spray product
It is hard to follow your question....however; if the sprayer turns on and the paint fails to enter the nozzle, you may have a blockage. Take the spray nozzle apart and run hot water over it to clean it out. You may need a small brush or cu-tip to clean the inside of the barrel. Blow though it and see if air passes easily. reassemble and run as you normally do. Be certain the top is attached to the paint reserve tightly and securely. Any air leaks will prevent the sprayer from building up pressure within and thus no spay will be emitted.
Dec 19, 2013 | Titan 440 Impact Airless Paint Sprayer...
Does Home Depot sell paint sprayers online on their site?
Yes, you can buy them or rent them, visit the below link or Google search "Home Depot Paint Sprayer":
http://www.homedepot.com/b/Paint-Paint-Sprayers/N-5yc1vZarv5
Oct 29, 2013 | Tools & Hardware - Others
My sprayer has power and blows air but no paint comes out
you have old paint that is pluging the pick-up line. you need to clean your sprayer very well each time you use it. I hope this helps you out some.
Aug 14, 2013 | Wagner SprayTech Paint Sprayer. Flexio 590...
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
I have a Wagner 834cw15. Spraying fine 10 mins ago. Now...can't get it to prime. Any suggestions? Spraying oil based kilz
http://www.wagnerspraytech.com/portal/loader.php
I cannot find model 834
Check your owner's manual for troubleshooting steps
We used paint sprayers every day for years.
The prime valve goes bad
The steel balls that direct the paint between prime and hose, wear out
The steel ball that holds prime and hose pressure wears out
The steel balls can also get stuck
Turn prime lever on
Take a hammer and tap/bang front of paint sprayer until ball comes loose
I cannot see your sprayer so I don't know where the ball is located
The photo below says, keep lever up >> in your case lever is down or in prime position while tapping
To post a photo of your paint sprayer so I can see it:
Read:
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answersAnd then add comment at page bottom and it sends me an e-mail
I will be here for another 45 minutes. Its 526 cst
Oct 26, 2010 | Air Tools & Compressors
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
GRACO INC Paint Sprayer. ProX7 Airless Paint Sprayer 261815 Logo
398 people viewed this question
Top GRACO INC Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a GRACO INC Air Tool and Compressor Expert? Answer questions, earn points and help others
