Question about Lands Phones
Gigaset C285 double line cordless phone .The base station doesn't show any information , but blink the light. I disconnected and reconnected the adapter three tries, but no use ... Pls help what I do for this problem..?
2 Suggested Answers
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
Why wont my cordless phone work no reception?
The cordless phones have to be registered to the base station (the part connected to the phone line). Perhaps they are not registered. Check you documentation for information on how to register them.
Jul 27, 2014 | Siemens Gigaset E455 Cordless Phone
The lights on the base station are not working. Yes, I have checked the owners manual.
The power supply of the base station is working correct? the cable from the power supply is not broken? and the cable from the power supply is inserted?
Just a few questions, things I would start with when my base station wold not have any lights.
Oops the base station of my Siemens Gigaset S79H does not have lights.
Jul 22, 2014 | Siemens Gigaset 8825 Cordless Phone
I need a manual for a verizon V100AM cordless phone
The V100AM was made by Siemens for Verizon. It's also known as the Siemens Gigaset C285.Here's the link to the manual.
http://gigaset.com/medias/sys_master/A31008-M1973-R401-2-5819_en_US_CA.pdf
Dec 31, 2012 | Verizon V100AM1 19 GHz 1Line Cordless...
Need a manual for Verizon V100AM
Aug 19, 2011 | Verizon V100AM2 Cordless Phone
Siemens gigaset 2420. how do i reset pin on desktop base corded station?
  1. I forgot the PIN number on my Gigaset 2XXX system base station. What can I do?
    Please complete the following steps to reset the system PIN on 2XXX back to 0000. On the system base station:
  • Press MENU.
  • Scroll to SYSTEM SETTINGS but do not press SELECT.
  • On the keypad, enter *65# (Star, 6, 5, Pound).
  • It will display "SYSTEM PIN RESET" and return to the idle screen.
  • Note: The base station system PIN will be reset to 0000
  1. I forgot the PIN number on my Gigaset 2XXX cordless handset. What can I do?
    Please complete the following steps to reset the cordless handset PIN on the 2XXX back to 0000.
  • Press MENU.
  • Scroll to MOBILE SETTINGS and press SELECT.
  • Scroll to LOCAL SETTINGS and press SELECT.
  • Scroll to CHANGE PIN and press SELECT.
  • Note: The handset PIN will be reset to 0000
Jan 05, 2010 | Siemens Gigaset 2420 Cordless Phone
Display shows "line in use
You should contact your service provider and have them reset your phone line connection. They should be able to do it remotely.
Sep 12, 2009 | Siemens Gigaset 4215 Cordless Phone
Siemans Gigaset 8825 BaseStation
Is the line blocked in settings at the base? This would be the only solution I can think of - hope it helps!
Dec 01, 2008 | Siemens Gigaset 8825 Cordless Phone
Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Sep 15, 2008 | Siemens Gigaset 8825 Cordless Phone
Siemens 8825 gigset 2 line phone
If your system was working fine, and it all of a sudden started doing this, it sounds like your base has taken a surge of some kind. Your base needs replacing. You can try re-registering the handsets, but from my experience the problem is fatal. Now if this is a new installation and the handsets never work yet on the base, you just need to register them. You can download the manuals or get tech tips at Siemens website, gigaset FAQ pages.
Sep 04, 2007 | Siemens Gigaset 8825 Cordless Phone
Lands Phones Logo
43 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
