Question about Lexmark Optra T610 Laser Printer
241 paper jam check tray 1 - Lexmark Optra T610 Laser Printer
5 Suggested Answers
SOURCE:
Cops
  • 64 Answers
SOURCE: when i try to print anything, i get a message 241 paper jam,
this is most likely to be worn pick up rollers. these are the two rubber wheels that you can see underneath the printer when you remove the tray. you should be able to source these from a local suplier and are very easy to fit. just make sure your gentle with the clip that holds them in place as if they break then you will need to buy a whole new pick up assembaly which is significantly more expensive.
hope this helps
Pete
Posted on Nov 25, 2008
  • 300 Answers
SOURCE: 241 paper jam
Check the paper tray guides, check the the paper feed roller (remove the tray and look up in the printer) it is possibly worn and needs replacing, you can try to clean it (hand soap is as good as anything)
Posted on Apr 24, 2009
don_farr
  • 1018 Answers
SOURCE: i have a optras1855 printer and a message keeps
I'll bet that if you put a mark on the top sheet of paper in tray one and then send a print job or run a self test you will see that the paper stays in tray one. I suspect that you have a paper pick problem.
Worn or slick rollers can be one source or a weak tray supports. Also, take the paper out of tray one and fan the paper to break any static that may cause the paper to stick together.
Don
Posted on Dec 17, 2009
sys_admin
  • 829 Answers
SOURCE: Getting the message
Turn the printer upside down and shake to find any paper jam as in most cases you will find some paper or dust falling out and then try.
Posted on Jan 26, 2010
241 paper jam message
Lexmark T630 241 paper jam message - Indicates a paper jam from the pull down manual feed tray.
If you check to make sure and small fragments of paper are not hindering the operation of the switch. The switch is located on the left side of the tray and will be spring loaded. The switch should move freely without binding. Make sure no toner or dust is on the optical sensor assembly. See Diagram for location.
If the switch seems OK and the printer still reports an error, the printer will require professional care.
Jan 15, 2011 | Lexmark T630 Laser Printer
Hello I am getting a paper jam error #241 "check paper tray 1 "
DEAR SIR,
Some print media, although they may conform to size and weight specifications, may not perform to your expectations. Print quality, jam rates, fuser life, and output stacking can be affected by the printing environment (temperature and humidity) and characteristics of the paper (structure, moisture content, smoothness or thickness);
Duplex printing is not supporteD
Using Auxiliary tray is recommended
HOPE THIS HELPS....
Thank you sir,take care
Oct 04, 2010 | IBM Infoprint 1332 Laser Printer
Getting the message "241 Paperjam Check Tray 1" I've checked tray 1 and have not found a paper jam
Jan 26, 2010 | Lexmark T630 Laser Printer
I have a optras1855 printer and a message keeps coming up 241 paper jam check tray 1. the problem is there is no paper jam. i know this because i have another machine the same model and that does the same...
Don
Dec 17, 2009 | Lexmark Optra S 1855 Laser Printer
241 paper jam
Apr 15, 2009 | Lexmark C510 Laser Printer
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
When i try to print anything, i get a message 241 paper jam,
hope this helps
Pete
Nov 11, 2008 | Lexmark T630 Laser Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
Lexmark Optra T610 Laser Printer Logo
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
