Question about Hoover Washing Machines
Hoover Dynamic 9 + 6 washer dryer error code E12
4 Suggested Answers
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Posted on Dec 20, 2010
SOURCE: error code E11 on hoover
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Posted on Dec 23, 2010
richroth
  • 9472 Answers
SOURCE: Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Posted on Nov 03, 2012
Hoover dynamic d3 dishwasher is showing error e7 ,can you tell me what this is .
This code relates to a failure of the control panel for the washer. You will need to replace it and check all connections for signs of overheating.
Feb 28, 2017 | Dynamic Computers & Internet
My washing has a E12 code on it.
I appreciate your inquiry, friend!
From what you have described your Electrolux washer is displaying an error code of "E12". An "E12" error code stands for a non-fatal reading or writing to the memory. This can be cleared with a reset and you can do that by unplugging the power cord for roughly ten minutes. If this does not resolve your issue it could be a possible problem with your control panel and that may need to be replaced. I hope this information is helpful. -Matt
Mar 15, 2015 | Electrolux Washing Machines
I have electric current going into the hoover DYN 9144DG washing machine but no display
board inside these washer has internal safety devices fuses on there pcb
you need to let a tech look at this
sounds like the psu to the controller board has failed
and you need to either replace or repair the controller board
Oct 03, 2014 | Hoover Dynamic 9 DYN9144DG White 600 mm...
Error e 12 frigadaire front end loader washer
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
Dec 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Nov 03, 2012 | Washing Machines
ERROR CODE H02 ON MY HOOVER SENSOR DRY WASHER DRYER WD9616C
Hi I have the error code ho2 on my Hoover wash machine does any one no what it means
Oct 21, 2012 | Washing Machines
Lent removal hoover dynamic 9+6
I have H02 on my washer dryer, all i can do is turn it on and off, i wont do anything else, what can i do to get it to work?
May 05, 2012 | Washing Machines
Error code E12 Bosch washing machine front loader
I have the Bosch Vision 500 Series with the E:12 error. My issue was the water inlet valve. When the washer was filling up very little water could be seen coming into the washer and if you just hit the button eventual you would get enough water usually three times during entire wash cycle. Replaced the water inlet valve myself in about 5 minutes very easy. YouTube videos show exactly how to do it. Now the water comes in almost covering half of the front window. Just finished first wash without and problems.
Apr 10, 2012 | Bosch Washing Machines
E12 eror on Haier washer dryier
Error 12 means Drainage error, water not emptied within 4 minutes
Solution:
Clean the fi lter and check the drain hose for blockage. If error still exists, please contact the Haier maintenance personnel.
Thanks and have a nice day.
Jul 03, 2011 | Haier XQG50-11 Front Load Washer / Dryer
Washing Machines Logo
101 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
