Question about Soundstream P5.610 Picasso 60 x 4 170 x 1 RMS at 4 Ohms 5 Channel Full System Amplifier
Soundstream p5-610 protection light on - Soundstream P5.610 Picasso 60 x 4 170 x 1 RMS at 4 Ohms 5 Channel Full System Amplifier
  • Steve
    Steve Oct 18, 2013
    how do i fix it its only 3 weeks old
Why would my 2500 soundstream Rub1 amp keep going into protection mode
Take a look inside it could possibly be a/some capacitor/s. If it is replace more than just one because they can also be going bad. This is a cheap fix they cost less than one or two dollars a piece.(if this is the problem)
Mar 30, 2014 | Soundstream RUB1.2500D 2500 Watts RMS Mono...
Protection light on
check your speaker wiring for shorts (+ & - wires touching)
check that for shorts between your 12v constant and Ground at amplifier.
If these are fine it may be an internal problem.
Sep 27, 2013 | Soundstream STL4.320 - 320W RMS 4-Channel...
Amp 1000sx
it sounds like protection mode is on check to make sure no wires are touching metal or the frame
Aug 19, 2013 | Soundstream Car Audio & Video
I have 2 Soundstream SPL 10 Car Speaker
need to know model number on amp, and the impedance of the woofers
Apr 06, 2012 | Soundstream SPL 10 Car Speaker
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
Soundstream rub1000d is not sending power to my subs
Does it have power indication, e.g. red light, green light
May 25, 2011 | Soundstream CAR AMPLIFIER, 1 CH, 1000 WTS...
Sounstream tra 560.2 always in 'protect'
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 01, 2008 | Soundstream Tarantula Car Audio Amplifier
CONNECTED EARTH TO POWER AND VICER VERSA
If it was properly fused, the fuse should have blown without causing any other damage. If it was not properly fused, it probably caused the reverse protection diode to short and burned a trace on the circuit board.
Any competent repair shop should be able to repair it unless the reverse protection diode opened instead of shorted. If it opened, the damage could be much more severe.
Jun 19, 2008 | Soundstream Davinici Car Audio Amplifier
Amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
Soundstream P5.610 Picasso 60 x 4 170 x 1 RMS at 4 Ohms 5 Channel Full System Amplifier Logo
52 people viewed this question
Top Soundstream Car Audio & Video Experts
richie46
ray gallant
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
