Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I have a GE side by side refrigerator, model #gsl25jfpa, that will not stop frosting up. I have replaced the motherboard, the little thing that attaches to the tube to determine frost, temperature sensor and of course the defrost unit itself. What else is there that could be the problem?
    Problem Solver:
  • 11 Answers
Michael, you probably have a bad thermistor. Based on your model number there are 3 thermistors in your unit. Since yoy already have done so much I would just replace all of yhem. The thermistors only cost about $8 to $10 and are easy to replace. Hope this helps.
Posted on Nov 24, 2013
  • 15 Answers
SOURCE: Frost gathering in freezer, icemaker dispenser freezes over
well check to see if door seal is split if it is get new one!! need to see photo of the frozon over dispenser- found before that when ice not bein used alot the odd time you will have to take out the ice in the bucket crack it up and put back in try this???
Posted on Feb 03, 2009
  • 172 Answers
SOURCE: freezer has developed some frost in the back
This is a fairly easy problem to solve. First thing you will need to do is defrost the ice on the inside back panel of the freezer. Then remove the back inside freezer panel. You will need to remove your freezer shelves to do this. Once the panel is removed you will need to defrost the coils and surrounding area. Once defrosted you will see your defrost heather on the bottom of the coil and a defrost thermostat on the top of the coil. The defrost thermostat is about the size of a quarter and about 3/4 inch thick. It will be mounted on the coil line. If you have a multi tester you will be able to check continuity through the heater by unpluging it. The defrost thermostat is a bit more tricky to check. It will not read continuity once it is warmer than 50 degrees. The defrost thermostat is a fairly inexpensive part so if your heater is good you may want to just replace the defrost thermostat and see if the problem goes away. The other possibility would be your control board. It is located on the back of the refrigerator and has a metal plate covering it, with sever 1/4 inch screws. This board causes most failures on your model refrigerator. Also a point to remember. This board has had several new upgrades from the one originally installed on your refrigerator. So make sure if you get a new one that you get the listed number I have given you. The older ones are cheaper but they are also not updated and will not function properly on your refrigerator. The following parts listed are the possible parts you will need. Please let me know if you need one and I can ship it to you in about 1-2 days. I do not charge shipping and I give free advise. Thanks and good luck with your frost problem. you can reach us at.
Michael Anderson
Anderson Appliance
(865)945-3808
mca0824@aol.com
defrost thermostat. #WR50X10068 $21.57
defrost heater #WR51X10042 $56.50
control board #WR55X10656 $185.50
Posted on Feb 17, 2009
  • 4 Answers
SOURCE: HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
Posted on Apr 08, 2009
SOURCE: Where is the defrost timer located on GE
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Posted on Jun 05, 2009
mgprice
  • 744 Answers
SOURCE: My freezer was developing frost / not cooling very good.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! and thanks for using Fixya. Mike
Posted on Jul 29, 2009
We have a GE Profile Model PFS22SBSBSS fridge (double doors on top, freezer below). Approximately once a month it stops working and the temperature slowly rises. If we empty it and unplug it for several...
There will be no simple answer or solution for the cause of this happening but knowing that your model has a motherboard that is prone to problems like these symptoms yours has does at the least point to many possible causes. Other things to consider are the possibility that a condenser or evaporator fan motor that is slowly going bad will cause this symptom and even cause the problems on the motherboard low voltage side to damage a new replacement motherboard should the board be replaced without knowing that there is also a problem with a fan motor. If it were me I would consider the cost of replacing the refrigerator with a model refrigerator without all of the electronic bells and whistles. GE thought they had a special product that would cut cost when going electronic as they did with the Artica/Profile models but what happened was many people are left with the cost of keeping these models going out of their pocket money. I will be glad to assist you in repair but first please weigh in replacing your model with something simple that has no electronic gadgets that in the long run cost much more to keep up. Thanks Sea Breeze
Feb 27, 2013 | GE GDS18LBR Bottom Freezer Refrigerator
Problem with my GE refrigerator model # GSL25JFPA BS freezer nor frig gets cold but there is still electric to it
check the gaskets on the doors to see if they r sealin proplerly if they r than that means that it is low on freon and it is cheaper to buy another refridgerator.
Aug 23, 2012 | GE GSL25JFPBS Side by Side Refrigerator
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
I have a GSL25JFPA BS that the frig side will not cool properly. Repalced the mother board. t stat in freezer and thermistor in frig. Freezer works fine. Damper will open when first plugged in but closes...
Unplug the refrigerator and then plug back in. Using multimeter check between J3-1 and J3-4.
Must be done within 10 seconds of starting. You should have 6 VDC. If you do replace damper, if not replace motherboard.
Jul 06, 2011 | GE GSL25JFPBS Side by Side Refrigerator
MY GE GSL25JFPA-BS SIDE BY SIDE REFRIDGERATORS FREEZER TOP PORTION IS NOT COOLING
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 09, 2011 | GE GSH25JFR Side by Side Refrigerator
GE Side By Side "frost free" fridge, Freezer keeps freezing over!
it is easy your thermostat is bad or your heating element is bad and it is very easy to check and replace ... what is your model # ?
contact me at www.911servicetoday.com
Dec 30, 2009 | GE Profile Performance 25.2 cu. ft....
Please help my side by side ge refridreator is
It sounds like the main control board is bad , IF , there is no frost on the inside rear freezer wall . The old board ( yours ) is under a factory recall . I would suggest calling GE factory service , to have this replaced under warrenty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
The new board part number is WR55X10656 .
If there is a frost build up , then that would be a defrost problem , with a different solution . Please reply back , if that is the case .
Nov 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling or freezing
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Aug 28, 2008 | GE GSS20IEP Side by Side Refrigerator
GE Refrigerator stopped cooling
I had the same problem. Replaced the damper switch and the motherboard. Then noticed the freezer has frosted over behind the panel in the freezer. Defrosted the freezer and all was working again. The same problem came back about 3 months later. This time the problem was diagnosed as the heater has gone bad in the freezer. Now waiting to have this replaced.
Jun 18, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
69 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
