Question about Homelite Garden
Manual for gas/oil mixture Homelite Blower 26bv
trippssmengi
  • 76 Answers
SOURCE: Oil Mixture
If it's not stamped on the fuel cap the I would try 50:1 if it smokes a little cut it back to 32:1 its always better to start with a higher mix when not sure any smoking is just the excess oil burning off in the muffler. It's better to have to much oil than not enough when it comes to 2 stroke engines.
Posted on Mar 17, 2009
slohry
  • 87 Answers
SOURCE: need oil gas mixture for homelite HB 100 blower
50:1 with premium oil i.e. Echo, Stihl, Husqvarna.
40:1 with Homelite or generic brands
Posted on Apr 12, 2009
  • 376 Answers
SOURCE: I nww=eed to know the fuel mixture for my homelite gas blower
If you ran plain gas in a 2-cycle engine and it seized... you need to buy a new one. 2-cycle engines depend on oil in the gas for lubrication. If you run straight gas, there is no lubrication, the engines overheats and seizes. The end, unfortunately.
Posted on May 25, 2009
miket756
  • 2702 Answers
SOURCE: I need to know the gas to oil mixture ratio for a
its about 40 to 1 mix but i would run it on a 30 to 1 mix as the motor last longer on that mix, look at it this way,,,if it smokes a little there is plenty of oil getting to the piston and bearings!!! so the engine lasts longer,,,
Posted on Apr 27, 2010
SOURCE: What is the correct oil to gas mixture for the
50:1 ratio
Posted on Jun 28, 2010
Need gas and oil mixture for 25 cc ut 08083 blower
Two-cycle engines use a mixture of oil and fuel to power and lubricate the engine. Homelite blower engines use a ratio of 50 parts gasoline to 1 part two-cycle engine oil. Two-cycle engine oil is commonly sold in 2.6-ounce containers; add it to 1 gallon of gas to achieve the 50:1 ratio. Two-cycle engine oil for outboard motors is not compatible with Homelite blowers.Use premium fuel,the blower,weedeater,etc. will last much longer!
Oct 31, 2015 | Garden
Homelite mighty lite 26bv gas Blower won't run full speed or only in Full Choke
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
Nov 10, 2012 | Homelite Mighty Lite Blowervac
I have the MightyLite 26bv....will only run at half choke. When turn knob to run, it dies. Does not reach full power ever.
The parts inside the carburetor need to be replaced (gasket and diaphragm kit) and/or the L and H screws need to be adjusted on the carb. Try grasping and turning the L mixture screw on the carburetor (one closest to engine) about 1/8 to 1/4 of a turn counterclockwise.
Jul 01, 2011 | Homelite Consumer Products MightyLite...
Need to know the oil and gas mixture for a homelite yard broom II
The manual probably says 40:1 (3.2oz.oil to 1 gal gas) but if you use a good modern 2 cycle oil,50:1(2.6oz .oil to 1 gal gas) will suffice.
Jan 31, 2011 | Homelite 'Yard Broom' Leaf Blower
Need to know gas mixture
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
What is gas/oil for yard broom?
what you have to do is get two cycle oil and follow intructions from container for mixture and after you mix put the mixture in your blower.
Nov 15, 2009 | Homelite 'Yard Broom' Leaf Blower
May 25, 2009 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
Need oil gas mixture for homelite HB 100 blower
Apr 12, 2009 | Homelite Consumer Products MightyLite...
Garden Logo
52 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
