Question about JoWood Productions SpellForce 2: Shadow Wars for Windows
I need File "sfx/but_hover1.wav" - JoWood Productions SpellForce 2: Shadow Wars for Windows
How to Online Convert MP3 file to WAV (Audio) file format?
The immigration attorneys Convert your audio like music to the WAV format with this free online WAV converter. Upload your audio file and the conversion will start immediately. You can also extract the audio track of a file to WAV if you upload a video. We are constantly improving our service. Right now we support over 20 input formats to convert to WAV. For example: MP3 to WAV, WMA to WAV, OGG to WAV, FLV to WAV, WMV to WAV and more. If you have a file that we can't convert to WAV please contact us so we can add another WAV converter.
Oct 09, 2012 | Audio Players & Recorders
I have steinberg clean 4 & 5 but both versions only show CPF file choice .i want to save as wav.
On the File menu you will find an option named "Export Audiotrack as WAV" as well as "Export Audiotrack as MP3". This will allow you to Save or Export the files you create as either the .wav format or the .mp3 format. Check your Help file, specifically page 86, if you need further information.
Mar 17, 2011 | Pinnacle Steinberg Clean 4.0 (210100265)...
Im trying to convert a QCP file to an MP3 file. I have a conversion program but it seems to be damaging the file, not full play time of the song/file and bad quality. how can I make this work?
Rename the file to .WAV (change the .QCP extension to .WAV) then you can either play the WAV file itself OR convert the WAV file (for free) with CDex.
Mar 02, 2011 | Computers & Internet
Is it possible to splice 2 msv files (one after the other) so they become one file? These files have already been transferred to my PC.
OK well in that case you could convert them to WAV and join that and play it that way? Download and install the Switch Audio Converter. Switch can convert between numerous audio file types and has the capability of reading MSV files.
Add the MSV file you would like to convert to the Switch converter. Click on "Add File(s)" and browse for the file in the search window that comes up. When you locate the file, click "Open" to import it to the converter.
Select WAV as your output file type. The .wav extension is one of the options in the "Output Format" drop-down menu at the bottom-left corner of the Switch screen. Choose an output folder for your WAV file. To find a folder, click "Browse" next to the "Output folder" box. Locate the folder where you would like to save the WAV file on your hard drive and click "OK."
Click "Convert" to begin the conversion process. The "Convert" button is in the bottom-right corner of the screen. When you click "Convert," a small window with a progress bar will pop up to monitor the status, and a pop-up message will inform you when the conversion is complete. The WAV file will now be available in your chosen output folder. http://www.softplatz.com/freeware/wav-joiner/
http://download.cnet.com/Switch-Audio-Converter/3000-2140_4-10703967.html
Feb 16, 2010 | Sony ICD-MX20 Digital Voice Recorder
I cant' read a WAV file with the Zen V plus I
try and convert your wav files to mp3 or wma whatever you prefer just google wav to mp3 converter that will ensure that your player will read it
Oct 02, 2009 | Creative Labs ZEN V Plus MP3 Player
Can you save file in WAV format?
The recorder will record the file in WMA format. You will probably need to search for third party software that will allow you to change the format from WMA to WAV. Do a google search for audio editing software that converts from WMA to WAV. Olympus does not provide any software that does this type of conversion.
Jan 22, 2009 | Olympus WS-100 Digital Voice Recorder
Load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Jan 10, 2009 | Tascam 2488 Portastudio Multitrack...
Plug in for downloaded ringtone
You can't actually do that.
If you have the original version Katana, the 6600, it's only plays polyphonic ringtones, in the qualcom format of QCB.
Freeringers.net has a good help section if you sign up with them, here's a cut and paste version.
You basically need a program to convert an mp3 to a wav file format. (like dbpower amp but there are many others, alot of them freeware).
Sound recorder on your computer applications, to pick a segment and crop the audio. Usually about 30 to 60 seconds is good enough. There's a file limit size on the Katana for downloads of about 100kb.
And a converter program that will convert wav to qcb. You can download an application from Qualcom Communications for free, or this little program called purevoice.
http://www.freeringers.net/apps/pvconv.exe
All you do is little drag the wav file over this application and it automatically compiles in about 3 seconds, a qcb file into the same folder.
http://www.qctconnect.com/products/purevoice_downloads.html
Provides the full version of purevoice convertor so you can listen to the quality of the qcb file.
You'll need an application to convert the MP3 or CD to a WAV file. We suggest this free tool:
dBpowerAmp Converter 10.1 (Download and install it)
You'll also need PureVoice for QCP conversion:
PureVoice Converter (No installation. Right click "Save Target As...")
If you're running Windows Vista you'll need the Windows XP version of Sound Recorder:
Sound Recorder (Right click link, "Save Target As...", save to "C:\Windows\System32\")
s_win.gif Conversion Steps:
Note: If you want to rip a song from a CD, replace step 1 with these instructions.
  1. We'll assume you're converting a file named "test.mp3" for this guide. Insert your own file name instead. Run dBpowerAmp and select the "test.mp3" file and click "Open".
  2. Change the drop downs to "Wave", "16 Bit (CD)", "8000 Hz", "1 'Mono'", Output To: "Folder", and "Browse" to select your "Desktop".
  3. Click "Convert >>" and once it's completed click "Finished" and you'll have a file named "test.wav" on your Desktop.
  4. Run Sound Recorder (included with Windows) and from the "File" menu "Open..." the "test.wav" file created in step 3. (if you can't find Sound Recorder, see Needed Applications above)
  5. Shorten the ringtone to 30 seconds or less. You can also crop it so it starts at the beginning of the choirs. To crop the audio clip, use the "Edit" menu to "Delete Before Current Position" or "Delete After Current Position". [?]
  6. Click the "File" menu and select "Save" which will overwrite the "test.wav" file.
  7. Grab and drag the icon for "test.wav" and drop it on top of the PureVoice icon "pvconv". It will convert and create a new file named "test.qcp", almost like magic.
Oct 04, 2008 | Sanyo Katana SCP-6600 Cellular Phone
How to convert audio in notes to wav?
This was a fun project. Here's how I did it. You'll need to download a freeware audio editor named Audacity. I did this on a Mac, but it's cross-platform, and I'm assuming the menus are the same for Windows. http://audacity.sourceforge.net/ Then. (1) Copy .pwi (Note) file to PC (2) Open Audacity (3) Get the Note audio into Audacity by: Project menu Import as raw data (4) Select all of the audio by clicking below its file name at left of the graphic of the file (5) Click on dropdown menu (arrow next to file name) Set Rate to 11025 Hz (6) Convert to WAV by: File menu Export as wav
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
JoWood Productions SpellForce 2: Shadow Wars for Windows Logo
41 people viewed this question
Top JoWood Productions Video Game Consoles & Games Experts
James Wishart
andrewcahoon
Carlos L. Burgos
Carlos L. Burgos
Are you a JoWood Productions Video Game Console and Game Expert? Answer questions, earn points and help others
