Question about Canon EOS Rebel G 35mm SLR Camera
Picture nearly all black
When taking a picture, it's as iff the shutter is all of a sudden very slow and creates an almost completely blacked out image. PLEASE HELP!!!!!
  • amyrose Sep 28, 2007
    I'm sorry ... It's a digital Rebel, SLR. I had that in the original description but not in the question. Any ideas??
    Problem Solver:
  • 3 Answers
Most likely shutter assembly separated. can be fixed with elmers glue carefull pull assembly together toward you in the full up position. using a fine artist brush put the smallest daub of elmers on each corner, then wipe off excess by pulling finger over back side of shutter toward yourself do not let shutter fall back into place yet. use some object to maintain shutter in full up position till glue dries, then you should be good to go
Posted on May 11, 2009
Lets see if the shutter curtains are opening properly : set to B and open the film back of the camera. Now release shutter and see if the first s. curtain has opened nicely and swiftly. Then release the second s. curtain and again see if you get proper closing of the curtain. If the shutter curtains ( usually just one misbehaves ) is slow to close then the shutter unit needs looking at . ( btw no point pouring liquids like benzine etc. into the shutter curtain are ... will make things worse ).
Posted on Sep 26, 2007
Pictures coming out completely black?
So???
Is the shutter opening? Put it on slow shutter speed and wide aperture say 1 sec at f4 or wider and look down the lens as you take photo. At some point you should see the sensor as the aperture is nearly fully open. If not then it isn't allowing light to get to the sensor, but if that's all working ok (and I assume you've looked at the photos on a computer and checked they are on the card and the exif info is sensible and they are still completely black) then you have a faulty sensor or processor. Remove battery reinsert and go into menu and reset the camera settings. Report back so???
May 13, 2014 | Nikon D3200 24.2 MP CMOS Digital SLR with...
My exilim camera is taking black pictures. Two days ago it was fine and all of a sudden when I turn it on the display screen and previous pictures are dark. When I take a picture or video now it is just...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 28, 2011 | Casio Cameras
When i turn the camera on and switch to picture mode the screen is completely black, and if i take a picture, the picture turns out completely black
Very easy to fix for your camera. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Recommend Fix 5A in the link, by gently flicking with your fingertip as described in the article.
Dec 22, 2010 | Canon PowerShot SD1000 Digital Camera
My Kodak EasyShare C713 suddenly takes only black pictures and shows only a black image on the LCD in live display. Playback is fine for old pictures and movies. Can I replace the picture senor element-...
It actually might just be a stuck shutter. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
Dec 19, 2010 | Kodak EasyShare C713 Digital Camera
Viewing screen is completely blank and will not take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 26, 2009 | Canon PowerShot A620 Digital Camera
Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon Powershot A510 black screen when taking photos
Jun 20, 2009 | Canon PowerShot A510 Digital Camera
Black strip across the top of the picture
I can tell you exactly what is happening. This is probably either happening when you are taking a photo with a flash? The maximum flash sync your camera has is 1/125 or 1/60 of a second. If you set your shutter speed faster than that, you shutter closes too slow and creates that black strip. Put the shutter speed to 1/60 or slower and see if that happens. If you have a long lens on the camera, you have to have the shutter speed either equal or less than the focal length to shutter. 50mm lens=1/50 a second without a flash. Otherwise you could have a bent or broken shutter curtain blade. Maybe someone stuck their finger in there.
http://www.cameradr.com/
He can fix it if you blades are broken.
Jan 02, 2009 | Nikon N75 35mm SLR Camera
Canon SD 550-- sensor problem? Bought 3/2006 and have had no problems. Suddenly, LED screen went black--shows nothing and cannot take a picture altho will flash and record black picture. Shooting...
The shutter of the camera is not opening that is why every picture taken is recorded black. It is a mechanical problem and probably has nothing to do with the sensor. Not very expensive
Aug 30, 2008 | Canon Cameras
Digital rebel / SLR photos are nearly all black
If the camera still "operates normally" with recorded pictures while they are all black, you try to select CMOS Cleaning to see if the shutter really opens or not. If not, a plastic lever operates the first set of curtains had broken. This could be common for all plastic shutter except EOS 1 series which use metal.
Sep 28, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel G 35mm SLR Camera Logo
304 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Norman Worley
Are you a Canon Photography Expert? Answer questions, earn points and help others
