Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
HP Laserjet m2727nf has the exclamation mark light on
  • 121 Answers
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Posted on Feb 23, 2010
seeker5211
  • 1089 Answers
SOURCE: HP Laserjet M2727nf Mfp.
Turn off printer. Hold the CANCEL and > buttons, and turn on printer. When you see Permanent Storage Init release the two buttons. When the process completes you will see the ready message. This will reset ALL menu settings. If you screwed up the firmware update, you will have to replace the formatter. The NVRAM reset won't help you!!!
Posted on May 17, 2010
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
Posted on Jul 26, 2010
  • 223 Answers
SOURCE: HP Laserjet M2727nf locks up /nothing works.
This is due to a formatter failure.
Try an nvram
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Posted on Jul 28, 2010
  • 89 Answers
SOURCE: My HP LaserJet 1320 is showing an Orange Light (
if the light is blinking it means
1. either the cartridge door is open
2. or paper tray is empty
3 or paper is misfeed
4. or paper jam
Verify that the print
cartridge is present and
that the print-cartridge
door is closed correctly.
2. Verify that media is
present in the input tray.
3. Clear any jams and
perform paper-path
functional checks.
4. Make sure that the
interlocks are operating
correctly.
Posted on Jan 12, 2011
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
How to get free download drivers for hp laserjet m2727nf
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
dont forget to vote
Feb 16, 2011 | HP Laserjet M2727nf Multifunction Printer
The printer turns on and it will turn on but it doesn't do anything. Nothing on the display screen shows up and the exclamation mark and toner low lights turn on and the 2-sided and collate LEDs are on.
This is a common issueon these machines, HP offers a free extended repair on units that show this problem as long as the date of manufacture is before January 1, 2010. You can find the date of manufacture on the back of the machine on the serial number label. Contact HP directly or any local HP service partner. Be insistint because I know some repair centers appear to be unaware of this free fix.
Dec 27, 2010 | HP Laserjet M2727nf Multifunction Printer
How to use scanner of the said printer HP LaserJet M2727nf
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01072069/c01072069.pdf.... check this link..this is the user manual of HP laserjet M2727nf MFP Printer
Nov 10, 2010 | HP Laserjet M2727nf Multifunction Printer
Faultcode 5 for HP laserjet M2727nf The scanner
This sounds like a Scanner/Flatbed Problem. "The printer report a Scanner Error 5" This series of printers have a known problem with this component. The scanner is failing to initialize itself. The scanner does need to be changed by an Authorized HP Warranty Repair Facility. It is possible that it may be covered under an HP Extended Warranty program. See repair information VIA posted Link.
M2727INFORMATION
Cheers!!
Oct 14, 2010 | HP Laserjet M2727nf Multifunction Printer
How re start my hp laserjet m2727nf, how delate
hold down the go button while you power on your hp laserjet.
Mar 19, 2010 | HP Laserjet M2727nf Multifunction Printer
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
120 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
