Question about Leica Reichert-jung Biocut 2030 Microtome
I need to adjust the x y axis the microtome was
I need to adjust the x y axis the microtome was purchased reconditioned and the copied instruction manual does not give that instruction.
I need leica 1512 microtome brochure
its a old post , but if you need one speak to ukmicroscopy.co.uk they will have a digital one for the 1512. How ever if you need any advice on how to use it contact me back via this forum
Apr 13, 2014 | Leica LEITZ 1512 microtome Microtome
Xerox c118 copy is not centered
Enter diagnostic: press "0" then "Start", enter System settings->CE Settings->MFC->Regist, enter 102 to adjust x-axis or 101 - y-axis, adjustment range x (-24 to 127), y (-72 to 72). 24 bit = 1mm. Good luck
Nov 20, 2013 | Xerox CopyCentre C118 Copier
My TEC SX4 has decided to do a wrap and my x-axis is offset from 0. how do i correct this problem?
The Wrap is due to the message being too long.
Inrease the width of the label. The 0,0 reference is relative to the paper width. To chage the X axis goto parameter set or adjust set depending on firmware. (X offset)
Nov 13, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
I need setup instructions for a Ozeri 4x motion pedometer. Thanks
Here is a copy of the instructions for the Ozeri 4x motion digital pedometer. I hope this is not too late. Regards.
Timothy Raines
Oct 28, 2012 | Ozeri 4x3motion Digital Pocket 3D...
What is the master XY SCALE
Press *28* then touch the adjust, increase/decrease the value to x scale to adjust the position of x axis, also increase/decrease the value to y scale to adjust the position of y axis
Sep 29, 2012 | Canon imageRUNNER 400S Copier
DEWALT DW079 LASER LEVEL CALIBRATION
You can not calibrate the Laser in the field it needs to be sent to a dewalt service center however you can check the calibration to see if it is off
download the manual here with instructions on how to check it
Jan 04, 2012 | Measuring Tools & Sensors
DW079 CALIBRATION
Here is how you get your laser into adjustment modeY axis; Power and scan key at same time, unit then will tip from Y1 to Y2, then recenter. use up and down arrows to bring laser into adjustment. Let unit stabilize for 30 seconds, press scan key, you will get a continuos beep, now at same time press down arrow key. This will store your new calibration.To get X axis into adjustment mode power on and up arrow at same time, and for Z axis type laser onto Z axis and use adjustment procedure for Y axis. Saving your calibrations is the same as in Y axis. Hope this helps you
Jan 04, 2012 | Office Equipment & Supplies
Hard to start! runs about three minutes and shuts down. reconditioned saw.
Clean Spark Plug or replace.
Drain fuel and fill with FRESH gas and oil mix.
Adjust carb.
Sep 10, 2009 | Homelite Garden
Need set up instructions for nintendo ds
found one here, let me know how you go
http://joeljohnson.com/kotaku/dslite.pdf
Apr 04, 2009 | Nintendo DS Console
I have an HP 4600dn that is having trouble printing color.
there is a setting in the menu to adjust
go to Configuration
adjust color
you have to determine which way to adjust it on a X and Y axis
try changing the number X to a high # to see which way it moves then adjust from there.
Nov 21, 2007 | HP LaserJet 4600dn Color Printer
Leica Reichert-jung Biocut 2030 Microtome Logo
35 people viewed this question
Top Leica Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
Tom Chichester
William McMath
Are you a Leica Science and Laboratory Expert? Answer questions, earn points and help others
