Question about GE Televison & Video
Procaster code - GE Televison & Video
Do you still have parts and manuals for a Diawa PR15 procaster
Parts are here, e.g...
http://www.ebay.com/bhp/daiwa-procaster
or here...
http://www.mikesreelrepair.com/
Schematics are here...
http://schematics.mikesreelrepair.com/thumbnails.php?album=8&page=8
Mar 15, 2017 | Music
Code for dvd procaster dvd 003
0241,0229,0218. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Aug 31, 2015 | Televison & Video
Getting a lot of noise from new Aphex Channel Master Preamp how do I fix this? I was using a Neuman TLM 103 mic and just recently switched to a Rode Procaster mic but still plenty of noise. I'm sure...
My thought is that this is a gain issue. Too much somewhere, and not enough somewhere else. Try experimenting with the input gain on the unit, and your mixer until you can reach a better noise floor. Otherwise, some units are noisier than other brands inherently. But experiment and see what you come up with. Also check for the +4 or -10dB switch. If there is one, it may be set incorrectly.
Apr 25, 2013 | Aphex Channel-Master Preamp and Input...
Is there anything I can download on my phone so I can hear or see my baby
I set something up that might work for you. I set up a webcam facing my daughter's crib which was hooked up to an old computer. Then I made a free account at Livestream.com (not affiliated w/ them). You can broadcast videos online, live (but there are occasional commercial interruptions w/ free account...didn't bother me much) and anyone you choose can tune in. I only used it for myself and occasionally my wife would watch from work :)
What I did was, before nap time, I'd start a broadcast on Livestream of the webcam feed, but I'd set it to PRIVATE so no one else could see the video feed but me. (you do this in the livestream settings)
Then when I put the livestream app on my phone I could log-in and watch my baby napping, live, on my iphone. It works best if you're using wifi on your phone but it works over 3g connection too. So you can watch from a neighbor's house or even across the globe really.
It takes an initial set up of about 20 minutes and after that, you just log-in and start recording' the video and watch from your phone. You have to install the free apps on your phone and computer though...I think it's called procaster.
They also make video monitors that are quite expensive and some may come with their own iphone app to watch on your phone. I hope this helps.
Mar 22, 2012 | Baby Care
I have a pair of 15" procast mmats and need to replace the rubber seal around the cone. Where can i get a repair kit ?
Well i havent had just the rubber problem, I've complete recoils. Contact MMATS. They should do it. http://www.mmatsproaudio.com/ Click contact then email
Jul 06, 2010 | Mmats Procast 15 Car Subwoofer
Hi I need PHILIPS P568 IMEI 351265412565412 unlocking codes.... please help me.
Codes for imei 351265412565412, model Philips P568 Unlocking codes: Code for NCKKN is : **00012*39094694# Code for NSCKN is : **00022*35077294# Code for SPCKS is : **00032*36089094# Code for CKCCK is : **00042*37037294# Code for PCKKP is : **00052*33054694# Code for XXXXX is : **00062*37035294# Code for XXXXX is : **00072*33775294#
Repair codes: Code for NCKKN is : **00013*43714762# Code for NSCKN is : **00023*43070742# Code for SPCKS is : **00033*43251752# Code for CKCCK is : **00043*43072702# Code for PCKKP is : **00053*43718722# Code for XXXXX is : **00063*43872702# Code for XXXXX is : **00073*43878442#
New Algo Codes Unlocking codes: Code for NCKKN is : **00012*7563374371217567# Code for NSCKN is : **00022*7161634379412367# Code for SPCKS is : **00032*7262814378202967# Code for CKCCK is : **00042*7367634371472367# Code for PCKKP is : **00052*7969374375277567# Code for XXXXX is : **00062*7367434371470367# Code for XXXXX is : **00072*7931434377110367#
Repair codes: Code for NCKKN is : **00013*2159969789537257# Code for NSCKN is : **00023*2185567789015457# Code for SPCKS is : **00033*2103668789074247# Code for CKCCK is : **00043*2185763789017417# Code for PCKKP is : **00053*2159365789531217# Code for XXXXX is : **00063*2165763789817417# Code for XXXXX is : **00073*2165337789813157#
May 17, 2010 | Belkin Cameras
Does mmats sell the rubber surround for a 12 inch procast? one of my procast needs a new rubber. Do i have to sent it in or can i fix it at home/
You can do it yourself if your handy. Lots of places out there selling them. Not too bad a job. Takes some patience gettiog the old one off.. If its really rubber and not foam, it'll come off in one peice. Have to be carefull the get the cone centered when ya glue the new one in. If you decide to tackle it get one with instructions and/or a good web search on the surround replacement.
Apr 06, 2010 | Mmats Juggernaut 15'' Car Subwoofer
Mmatsd500.2
First, the specs:
  • PPI 4200am = 50x4 at 4 ohms, 100x4 at 2 ohms
  • Alpine 3553 = 35x4 at 4 ohms, 50x4 at 2 ohms
  • Mmats D500.2 = 350x1 at 4 ohms, 500x1 at 2 ohms
  • 3x Mmats Procast 12 = Dual 4 ohm VC
  • 1x JL 15w6 = Dual 6 ohm VC
  • 2x JL 15w0 = Single 8 ohm VC
Second, I don't think I would recommend mixing n' matching the subs. One of the subs would always be working harder than the rest. If you want to run multiple subs, make them all the same. Sometimes, you can get away with it if they are all the same voice coil impedance, but in this case you've got dual 4 ohm, dual 6 ohm, and single 8 ohm subs all in the mix.
If it were me, I'd probably stay with the single 15w6. But it's your money :)
Mar 12, 2008 | Mmats D500.2 Amplifier Car Audio Amplifier
Televison & Video Logo
15 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
