Question about Whirlpool Clothes Washer Control Panel - W10196933
I have a Whirlpool NTW4800XQ4 Model washing machine. When I leave the lid up after starting machine and go to get some items to add to load, the water drains out before I can get back. I also like to put stained items in washer to soak but it drains water out which is wasteful. Is there a way to eliminate water drainage?
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
huuum
  • 750 Answers
SOURCE: Getting HF error, on Whirlpool Front load washer
Dear jodyheidi,
Welcome to fixya.com
I'm Huuum and happy to assist you,
Try this first and if it fails to remedy the problem then call service as you wanted!
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
let me know how it works out.
How old is the appliance?
Let me know how you progress!
Bless You, Huuum
Please remember to leave a rating when you are finished!
Thank You
Posted on Sep 23, 2008
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
  • 97 Answers
SOURCE: Whirlpool washing machine makes grinding noise
Hello Friend, Your solution is a real quick fix. The problem you are having is very common, your motor coupling has broken and that is what's making the grinding sound, also in this condition it will always pump out the water. Go to your local appliance parts store and purchase a new motor coupler, your cost should be under $25. It's very simple to remove old and install new coupler. First remove two screws from control panel and tilt control panel backwords exposing area under panel. You will see a metal clip on each side of cabinet under panel. Remove these clips, and unplug wires from plug in on cabinet. Remove cabinet by lifting up in back and tilting forward. Once removed you will see the innerworkings of your washer. Lay washer on it's back and remove the two spring clips that hold water pump in place and remove water pump. Leave water pump hooked up just move to side out of your way. Then you will remove the two screws that hold the motor clips in place and just snap the motor clips off. Be sure to unplug the wire harness plug from the motor. Just simply lift the motor straight up and off of the transmission. There you will see the motor coupler broken and to replace, just pry old one off transmission and motor with large flat head screwdriver. You will notice that one half of coupler is attached to the motor and the other to transmission. In the coupler kit you will receive both pieces and the rubber center connector. Just replace all the old with all the new and your problem will be solved. Happy to help, Tim.
Posted on Jun 24, 2009
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
Whirlpool wtw5tesvno
Hello.
Whirlpool washers are available in many colors and with different options, including various tub sizes, front or top load styles, a fabric care system, high efficiency wash features and energy, time and water sensors. The washers may be purchased in department stores, home repair stores and online. Many are Energy Star rated. However, the washing machine may malfunction occasionally and not agitate or spin. If this occurs, some troubleshooting steps may be useful in solving the problem.
1 sure the washer has electrical power and is connected to a grounded electrical supply. Replace or reset the circuit breaker or fuse if needed, particularly in event of a recent power outage. Make sure the washer lid is closed tightly before use; the washer won't work if the lid is open.
2 void selecting the following cycles: "Extra Low,, "Low," "No Spin", "Delicate," "Casual/Perm Press" or "Hand Washables." All of these cycles use little to no spinning or agitating during the cycle. Select the highest possible spin cycle for the fabrics being washed.
3 pen the washer lid and redistribute the load; unbalanced loads may cause the washer to stop or slow down. Add additional items if only one large item,
such as a rug or blanket, is in the washer.
4 Use only the recommended amount of laundry detergent, as excess sussing can reduce the overall spin speed or cause the washer to stop agitating. If the Whirlpool washer is a high-efficiency model, use only high-efficiency laundry detergent.
5 Examine the drain hose and straighten if kinked. Remove any possible obstructions and ensure the end of the hose is no more than 96 inches from the floor, as this will cause water to flow back into the washing machine.
Thanks.
Nov 13, 2011 | Whirlpool Washing Machines
Why doesn't it do a spin cycle all the time
The lid switch, most likely, place a heavy item on the lid , may solve the problem if so
add a stiff rubber tube to the tap that operates the lid switch to give it more purchase.
May 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine fills but wont start
This may over simplfy things but... check to make sure there is an audible click of the lid switch just as the lid opens and closes. No click = exact symptom your described. Also make sure the plunger is still attached to the lid that actuates the lid switch.
This would be the lid swtich for your machine if it has failed:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Lid-switch-assembly-item-number-AP3100003.aspx
Thanks for using FixYa.
Kelly
Apr 04, 2010 | Kenmore 24032\24036 Top Load Washer
My Whirlpool Cabrio top load washer won't start now but it first started by giving LD code when would wash only heavy items like full load of towels or bedding (all others ok). If I let it sit for awhile...
we ran into this problem with ours too. I swear, this washing machine is the biggest piece of junk I've ever bought.
We used to get the LD code at the beginning of each load of wash. We solved this by manually holding the lid down tight until the lock mechanism clicked in place. Once locked, it should stay that way for the duration of the wash cycle.
One day, it just stopped giving us locking problems.
Sep 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Washing Machine that doesn't complete the cycles
I too have a whirlpool top load and it did the same thing. I would put a load in and go back and the clothes were sitting in water. I found that if you close the lid and press gently til you hear a click, it will finish the cycle. So now when I load the washer, I press the lid like that and I have not had the problem since. I hope this helps.
Jan 20, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Washer displays message of dl when trying to start washer
Hello bculwil Welcome
“dL” (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid
keeping it from closing. Press PAUSE/CANCEL once to clear
the code.
Or the lid lock sensor is faulty and needs to be diagnosed and replaced
Please remember to leave a solved rating before signing out.
Thank You Huum
Dec 21, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Clothes Washer Control Panel - W10196933 Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
