Question about HP OfficeJet D125xi InkJet Printer
D125xi problem Our d125xi printer just started rapidly flashing all the lights on the printer console. At first we needed to turn it off then turn it back on to fix the flashing light problem, so that the printer would work. Now when we turn it off, it turns itself back on and the lights continue to flash rapidly. It now takes 20-30 times turning it off before it seems to "re-set" itself and work properly. Any ideas as to what is happening?
Hi if you open the left part of the front cover, after you released the the top (scanner) to lift off, you will be able to find a batterie. Remove the batterie and try again. All should be done when the unit is powered off and disconnected from USB. BR Karlh.
Posted on Oct 06, 2007
Why does the red light om my 2002 crown vic flash fast when I attemp to start it
Which red light? The one on top of the dash? If so, there are two cases where that light will flash rapidly: If you use the wrong programmed key, it will immediately start flashing rapidly when you turn on the ignition and try to start the car. If the light is steady and then starts flashing rapidly after a few seconds when you turn on the ignition or try to start the car, you are using the correct programmed key but the engine computer has a problem or has failed.
May 31, 2012 | 2002 Ford Crown Victoria
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Three flashng lights on xbox 360
Please go through the Website link mentioned below.
Please let me know if you have any issues.
Feb 12, 2010 | Microsoft Xbox 360 Console
Green light blinks rapidly, cds, games etc dont load.........bran
"big motor noise?" do you hear any clicking? how old is your console?
Nov 29, 2009 | Microsoft Xbox 360 Pro System Console
All Lights Flashing
Your printer need service. Its firmware problem. All lights flashing error state usually indicates a hardware problem of your printer.
Aug 04, 2009 | HP OfficeJet D125xi InkJet Printer
Vista Drivers
When you click on File and print - ensure the selectionis in Active sheets (this will ensure that it only prints pages with texts in excel
Aug 31, 2008 | HP OfficeJet D125xi InkJet Printer
Blank Pages HP Officejet d125xi
Here are a few things to try: 1. Remove and then reinstall the ink cartridges 2. Clean the ink nozzles because they may be clogged which can be done manually or sometimes using the printer control panel like so: Open the print or fax window > right click on ink jet printer icon > select Properties > on the general tab click printing preferences > click services tab > click clean the print cartridge. If you have this option it will automatically clean the print nozzles, if not you will have to do it manually (check your documentation if you still have it for details on how to do this). Take cu-tips and remove the ink cartridges > dip the cu-tips in distilled water (not tap water) and squeeze any excess water out of the cu tip > Hold ink cartridge so that the nozzle plate faces up and use the swab to wipe clean the area around the nozzle plate > Hold cartridge up to light to make sure all dust, dirt, dried ink, or cotton fibers are not left behind > Dry them off and replace into printer and print a test page. 3. Try different settings for the print quality to see if any changes occur. 4. Turn the printer on and leave it on for about 30 minutes to warm up to loosen or melt any dried ink that may have blocked the nozzles. If this does not work there may be more serious problems that will require a qualified technician to deal with. Hope this helps and let me know if you need further assistance.
Jul 05, 2008 | HP OfficeJet D125xi InkJet Printer
EMT, sounds like the printer is having a seizure. You need to unplug the printer from the machine and unplug the electric. Turn off the computer. Plug in the printer electrically(if the printer still blinks furiously the printer is fried) in it turns on normal, plug the printer into the computer and turn on the computer. If the computer boots up the the printer starts spazzing again its the printer drivers(most likley). In that case again unhook and unplug the printer go the the HP site and download the latest and great est drivers and go through the installation process . Tim
Jan 29, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP OfficeJet D125xi InkJet Printer Logo
153 people viewed this question
Ben Johnson
