Question about Konica Minolta Bizhub C353 Color Copier Printer Scan Fax
MINOLTA C353 ERROR CODE C-164 HOW TO RECTIFY - Konica Minolta Bizhub C353 Color Copier Printer Scan Fax
Kevin Hayes
  • 167 Answers
SOURCE: multiple copy error
Turn OFF sorting and/or grouping in the finishing tab.
Posted on Dec 05, 2008
  • 5 Answers
SOURCE: Konica Minolta C353 has a C4551 error, how do I fix it?
try replacing the imaging unit with a new one not a reset imaging unit
Posted on Sep 02, 2009
  • 12 Answers
SOURCE: Konica Minolta C353 - Error Message C-4554
The C-4554 error identify a Laser Malfunction (K).
You could check flat cable that connect laset to logic unit.
Chech all laser K cables/connections.
If persist you have to change Lasers group.
Bye.
Posted on Oct 14, 2009
Testimonial: "Thanks for this helpful reply!!"
  • 7 Answers
SOURCE: i am having this error message with my konica
This is a tcr fault with the black i/u check the toner or i/u if tone has just been replaced check the seal on the unit sometimes the break and no toner comes through =if not look at replacing the i/u
Posted on Mar 04, 2010
saxmansaxman
  • 177 Answers
SOURCE: My Konica Minolta Bizhub C353 is showing a C-4553
Hi this error is a laser malfunction withe the yellow assembly you will need to change the yellow print head unit what you can do is take out the print head unit assembly swap the yellow print head unit with the cyan unit then you should get error c-4552 then you know the unit is faulty
this will fix your issue
Posted on Feb 12, 2011
How do you fix code error 5102 on konca minolta bizhu c353
check the paper draws and registration assembly. or might have a burned out transport motor worse case main board
Jan 23, 2017 | Konica Minolta Minolta Bizhub C353 Copier
BIZHUB 164 error M2 what have I to do
Replace the developer and the drum make sure counters are cleared first and that Gradation adj is run along with Toner adj
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
replace the drum and developer and then reset the counter
Bizhub 164 error code CC153
Have a tech come and re-flash the firmware, and check the NVRAM. Firmware is only available fro secure Konica Minolta Web site they like to keep they software secure. You mite also have a bad control board. Or the memory on the board, a Tech is required.
May 08, 2014 | Konica Minolta bizhub Office Equipment &...
C0202 bizhub c353
open the draw check for any paper behind it, THEN REMOVE ALL OF THE PAPER SITTING ON THE LEFT SiDE OF THE DRAW
NOT A STORAGE AREA. for 11 x 17 paper
Feb 05, 2014 | Konica Minolta Bizhub C353 Copier
KONICA MINOLTA C353 ERROR CODE C-5102
hi tracey, 5102 is a main motor failure, it is possible for there to be paper jammed tight in the fuser unit, if not this will pretty much be guaranteed to be the main motor
Nov 11, 2013 | Konica Minolta Bizhub C353 Copier
Error code c2558 in konica Minolta bizhub 164
help me my konico minolta bizhub 184/164 error (C2558) my mail id ganaa_et24@yahoo.com
Sep 30, 2013 | Office Equipment & Supplies
"konica minolta bizhub c353 error code c-4154"
"konica minolta bizhub c353 error code c-4154" help
change the chip and the imaging unit and still the same
what else I can do ??
help me please?
Thank you ...
Mar 09, 2013 | Konica Minolta Office Equipment & Supplies
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit.
Mar 13, 2012 | Konica Minolta Konica Bizhub C353 Drum...
I have problerm with konica minolta c353 .. the error code c4554 showing on display. i cant printing....
this is an easy fix, have you had your fuser replaced recently?? if so then it needs reseated or just do a trouble reset. ask me if you need help with that
Dec 19, 2010 | Konica Minolta Konica Bizhub C353 Drum...
Konica Minolta Bizhub C353 Color Copier Printer Scan Fax Logo
274 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
