Question about Panasonic NV-GS25 Mini DV Digital Camcorder
LCD no image
I bought panasonic NV-GS25 in 2005 and now its LCD is not working. I can see the video and photo image via viewfinder. When I open the LCD the viewfinder will switch off. I only take and playback the video using the viewfinder while the LCD closed. Any solution for this problem. DR NO
  • 6 more comments
  • Anonymous Nov 12, 2007
    i am facing the same problem. my camera's LCD cable is broken due to which lcd is not working. i can't even find a service centre in jaipur. kindly help me.
  • Anonymous Feb 14, 2008
    I purchsed panasonic NV-GS25 in 2005 and now its LCD is not working. I can see the video and photo image via viewfinder. When I open the LCD the viewfinder will switch off. I only take and playback the video using the viewfinder while the LCD closed. Any solution for this problem
  • iyanpo22 Oct 01, 2008
    im having the same problem.Each time I will open the LCD,the image is gone.I can only see the video in the viewfinder while the LCD is close.Pls.tell me how to fix it!
  • Anonymous Nov 14, 2008
    same problem with my camcoder no image on LCD but can only view using the view finder.
    my
    panasonic NV-GS25 Mini DV Digital Camcorder was purchased in Australia in Queensland 2005. it developed the problem this month. when using it in kenya. please advise: my address is [email protected]
  • Anonymous Nov 22, 2008
    no image on LCD
  • Anonymous Nov 29, 2008
    Same issue - no more Panasonic for me.............
  • SinIQ Dec 28, 2008
    Same friggin' problem!!
  • sanjay3332 Jan 03, 2009
    i have same problem at first when i open little bit it was working but now it is totally not working if you have any solution please email me on [email protected]
It is same with my camera same type also.the problem is from flexible cable from mainboard to lcd .same of the core is break..until now i can'ot get that cable.
you just buy the cable and on your camera and ok.
if you have information abaut that cable please submit to me
[email protected]
Posted on Oct 22, 2007
I change the cable and now it is working
thanks
Posted on Jan 27, 2010
At least tell us where to find it
Posted on Oct 11, 2008
SOURCE:
Not working
Remove bottom plate by unscreewing the 7 screews (for one of them you must open the viewfinder) and make sure the ribbon cables are connected securely . You just need to push genty the ribbon cabbles and reposition the plate, this should solve the problem.
Mar 12, 2008 | Panasonic NV-DS65 Mini DV Digital...
Panasonic NV-DS65 -
I seem unable to connect my Panasonic NV GS30 via firewire tried 2 cables and 2 computers windows does not see camera like it used to. Only other fault that has appeared is jitter on viewfinder display.
Hello, and maybe this can help! Sense your viewfinder has jittered, your computer has reconized it. However, your software that you are using on the computer may be corrupt. i suggest that you insert the cd and instead of removing it, click repair. If this does not work, try checking the cable and make sure that it has a tight connection. One question. Did you pc make the standard beep noise when you plugged it in??? if not, then it is your computers. most likely, it is your camera or your software.
Feb 27, 2008 | Panasonic NV-GS30 Mini DV Digital...
No image on lcd for Panasonic nv-gs50 camcoder
It was my question and I have found an answer.The problem was,due to faulty main PCB,which did not supply power to LCD backlight. I was lucky enough to find same faulty model on eBay,sold for spares (around $15 for the lot).I have also purchased a service manual for $10,just to see,how to disassemble a unit.It was pretty easy,not a rocket science.Any new replacement part usually very expensive,not saing about repair in repair shop.Will cost fortune.My advice: try to find similar not working unit on ebay,just figure out what was wrong,as there is no point to get unit with the same fault.The camera I have bought for parts had a mechanical problem,chewing tape.
Jan 22, 2008 | Samsung DouCam VP-D5000i Mini DV Digital...
HOW DO I DOWNLOAD MY PHOTOS AND VIDEOS FROM THE CAMERA
I just bought the same camera and Windows Movie Maker via usb works but not super quality....also get yourself a firewire card to gain better quality, hope this helps.
Dec 15, 2007 | Panasonic Video Cameras
Camcorder LCD screen only operates up to 30 degrees from camera
open the unit. find the flat flexible connector to the LCD and then look at each end to verify if fully inserted into its mating connector.
May 30, 2007 | Panasonic NV-GS15 Mini DV Digital...
Lcd monitor and viewfinder not working when i try to record myself.
the flex wire of the lcd monitor is have a open line that why it is not functioning....there is also a switch to on the viewfinder connected to lcd....in some model even the lcd is damage you can still use the viewfinder...
Feb 17, 2007 | Panasonic PV-GS31 Mini DV Digital...
LCD kaput - anyone know of a panasonic recall?
The panasonic camcorder does not use the Sony CCD element. If the small viewfinder is showing the camera video, there's nothing wrong with the CCD imager. We have had numerous problems with the switch that controls the activation of the large LCD and the backlight inverter that powers it. When you open the LCD the small viewfinder should power down to conserve battery power. The large LCD should then illuminate, if not, shine a flashlight at the surface of the LCD and notice if the video is present, if so, the backlight or LCD harness is defective. Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | Panasonic Palmcorder PV-GS120 Mini DV...
Panasonic NV-GS40
the possible fault may be bad image senser CCD. you require a professionl to change the CCD.
Jun 22, 2006 | Panasonic NV-GS17 Mini DV Digital...
Panasonic NV-GS25 Mini DV Digital Camcorder Logo
260 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
