Question about Olympus CLV-10 Endoscope Light Source
I need a user manual for my olympus CLV10 endoscope light source
I need a Printed users manual for my Olympus E620 ( NOT DOWNLOAD )
You can order the manual from Olympus at
https://emporium.olympus.com/studiomaster2/ManualsForm.aspx?id=1359
Aug 01, 2011 | Olympus Cameras
I need to find a users manual for the Olympus SP-600UZ Digital camera.
You can download the user manual for this camera from this link, just click HERE.
Oct 20, 2010 | Olympus SP600UZ Digital Camera
Hi - is it possible to remove the lens from an Olympus C-7070 camera? I want to try to fit it on to an inverted microscope with a bayonet fitting. Thanks, Paul
The lens is not designed to be removed and the camera will not function if you do manage to do so as it will report a lens error. To avoid this will involve bypassing various microswitches, simulating missing inputs and making other custom modifications to your camera. It's not impossible but you'll be on your own with the modifications, adapting and inventing as you go.
Ideally you either need a suitable SLR with an adaptor, or a camera which will accept an adaptor onto the front filter fitting (not all compacts and bridge cameras have them though).
You'd best contact Olympus directly for suggestions: they're a major microscope manufacturer and have always had the best solutions for using their cameras with microscopes. They have in the past produced a surprising number of microscope adapters for their models and have often produced special versions of their cameras designed solely for use with microscopes, endoscopes and similar non-standard applications.
Aug 24, 2010 | Olympus C-180 1.70x Lens Converter
Does canonZR950 have a DV- In ? (Is a DV port always a I/O port)
This is incredible - I didn't know such a thing existed - but it does appear that the DV port on that camcorder is bidirectional, so it will serve as an input when connect to a source with a DV out. Very nice!
A lot, of course, will also depend on your endoscopic camera. I have seen endoscopic cams that would definitely be compatible with your Canon. But I saw a particular JVC endoscopic cam that would not be compatible. What is the model/manufacturer of the endoscopic cam?
Here is a copy of the manual for the Canon:
http://gdlp01.c-wss.com/gds/0300000762/zr950nim-en.pdf
-Tha Mp3 Doctor
Feb 21, 2009 | Canon ZR-950 Mini DV Camcorder
Olympus CLV-10 Endoscope Light Source Logo
50 people viewed this question
Top Olympus Science & Laboratory Experts
Are you an Olympus Science and Laboratory Expert? Answer questions, earn points and help others
