Question about JVC HD-61Z886 61" Rear Projection HDTV
Turn the TV on and the blue light in front turns on for about 30 seconds and then starts to blink rapidly. Nothing else happens.
mfspencer
  • 58 Answers
SOURCE: blue light in the front blinking no picutre no sound
This is the shutdown code for the lamp ballast. I would have a technician verify ballast is bad and replace. This can be a tricky repair for a novice because installation of the ballast requires that you remove the light engine. Hope this helps.
Posted on Apr 02, 2008
SOURCE: HD61G787
Its the lamp
Posted on May 03, 2008
SOURCE: JVC HD-56G887 wont turn on
Your TVneeds to be serviced by a JVC authorized service center.
Posted on May 11, 2008
SOURCE: tv troubleshooting
I have a 61" JVC that just stoped working. I turn it on and nothing bu the blue light stays on and the red light blinks 8 times and then the blue light joins in.
Posted on Nov 03, 2008
karthik1989
  • 46 Answers
SOURCE: JVC AV48P575 projection TV turns on then turns off
you need to change your trigger circuit
Posted on Apr 05, 2009
Tv turns on for less than 30 seconds and turns off and red light is blinking
Hi John,
TV going off in thirty seconds and red light blinking means there is something wrong inside your Tv and it should not be working in this condition and hence is the "going off" happening. The automatic protection inside is switching your tv off. Please consult some local TV tech. There is nothing you can do about it yourself.
Good Luck.
May 23, 2015 | LG Televison & Video
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Aug 13, 2009 | Televison & Video
POWERING ON
good day
since it is unusual, have it checked by a competent technician. it may only be a simple reset but nevertheless at least you wont be bothered again by that problem
Oct 09, 2008 | Sylvania LC260SS8 26 in. LCD Television
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Nov 08, 2007 | Televison & Video
Red light blinking rapidly...no picture
Gentlemen, I have seen people with this problem and it requires the replacement of the light engine, search AVS Forum, for more information. Understand it is not cheap, hope you have ext warn.
Sep 25, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
JVC HD-61Z886 61" Rear Projection HDTV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
