Question about Zyxel Communications 300 Mbps Wireless N Gigabit Firewall VPN Router (VFG6005n
What are the settings to make this a repeater?
    Master:
  • 359 Answers
It may not be possible to make this router a repeater. At least not with the stock firmware that is on it. You may have to look into installing a new UI firmware onto it that will enable this functionality. Something like Tomato.
Posted on Oct 18, 2013
How do i turn on shuffle
Hi Nonya Buisness,
  • Music Submenu
To enter the Music Submenu, press and hold the OK/VOL button for 3 seconds.
AB Repeat
When you select "AB Repeat", you will be returned to your file, and "A-" will be displayed on
the playback screen. Briefly press PLAY to set the "A point" and "-B" will be displayed,
briefly press PLAY again to set the B point, and begin playing you're a-B selection. The icon
will change to "A-B". If you press PLAY again, you will cancel A-B Repeat.
Repeat
To adjust your repeat mode, select "repeat". You can select Sequence, repeat one, repeat
all, shuffle, or shuffle and repeat
**Pressing M will lead you to top menu.
http://www.eclipsemp3.com/180G2.pdf
Mar 02, 2014 | Eclipse 180g2 4gb mp3 music/vid
Tip
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's...
1. Connect your computer to the repeater router's RJ45 portwith a LAN cable.
2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1
3. Enter the configuration user name and password. The router will display the various router settings.
4. Go to the page that changes the IP address of the router.Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10 or higher), such as 192.168.1.10 or higher, depending on how many devices are on your network.
5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses.
6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router.
7. Disable any firewall settings on the repeater router.This is usually in the "Security" section, depending on the make and model of your router.
8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet.
9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only.
10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater.
11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
on Feb 14, 2011 | Computers & Internet
Can i use my old usr 5461 wireless max g as a repeater?
SETTING A ROUTER AS A REPEATER1. Connect your computer to the repeater router's RJ45 portwith a LAN cable. 2. Open a browser, then enter the router's URLconfiguration's IP address, This is usually something similar to 192.168.0.13. Enter the configuration user name and password. Therouter will display the various router settings.4. Go to the page that changes the IP address of the router.Changed the IP address so that it is not the same as the main router on thenetwork, or any other network devices. If the main router on the network is setto 192.168.1.1 then the repeater router should use a higher number (ie. 10),such as 192.168.1.10 or higher, depending on how many devices are on yournetwork.5. Disable the repeater router's DHCP server. This settingshould be on the same page as the IP address, (this may be different dependingon the make of the router). When the main router is operating normally, thisserver assigns an IP address to every device that is connected to your network.Because this router is used as a repeater, the main router on your network willstill issue the IP addresses.6. Also turn off the DNS server, if it is activated. Thisfunction will be taken over by the main router.7. Disable any firewall settings on the repeater router.This is usually in the "Security" section, depending on the make and model ofyour router.8. Remove all in the "Port Forwarding" section. Some routersmay refer to this as "Applications and Gaming," and it allows less-restrictedaccess to the internet.9. Set the operating mode switch to "Gateway" or "Switch" ifapplicable. Also, if the repeater router is a wireless router then disable thewireless access or set it to access point only.10. Save the settings for each page, and reboot the router.When the router boots up, the changes will allow it to act as a simplerepeater. 11. Now, place the repeater router in a newlocation and connect both routers with a Ethernet cable in each
Jul 18, 2012 | U.S. Robotics USRobotics USR5461 Wireless...
Lost manuel....how do I set the day and time....
1. Turn on the system. Hold down
SKIP/TIME SET/CHECK. The
system sounds a tone after 1
second.
2. While holding down SKIP/TIME
SET/CHECK, press REPEAT/ANNC/
DAY. The system announces
"Monday" and &'?appears on the
display. Repeatedly press REPEAT/
ANNC/DAY until you hear or see the
correct day.
3. While holding down SKIP/TIME
SET/CHECK, press MEMO/2 WAY/
HOUR. The system announces "1
AM". &' appears on the display.
Repeatedly press MEMO/2 WAY/
HOUR until you hear or see the
correct hour.
4. While holding down SKIP/TIME
SET/CHECK, press PLAY/PAUSE/
MIN. The system announces "01".
Repeatedly press or hold down
PLAY/PAUSE/MIN until you hear or
see the correct minute.
5. Release SKIP/TIME SET/CHECK.
The system announces the day
and time you set.
6. To hear the current day and time,
press SKIP/TIME SET/CHECK while
the system is on or off.
Thanks!
Mar 29, 2011 | Radio Shack 3808 Digital Answering Machine
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
How do I set it to play random songs?
While a file is playing you can enter the Music Submenu by pressing the “M” button briefly. The Music Submenu allows you to adjust your repeat mode, amongst other things.
The Repeat Menu allows you to set your repeat mode. Choose from Normal, Repeat One, Folder, Repeat folder, Repeat all, Random, and Intro.
Choose Random.
Here is an online version of the manual, incase you have any other problems you want to read about. http://www.eclipsemp3.com/CLD2manual.pdf
Feb 27, 2010 | Eclipse CLD2 MP3 Player
Repeater channels
Are you certain you are near a GMRS repeater in your area? If you have your radios set for the GMRS repeater channels the radios will not talk to one another unless you are in close proximity of a GMRS repeater. To talk radio-to-radio you would need to set your radio to one of the simplex frequencies available in the radio.
If you know you are close to a GMRS repeater, you might double check the Tx and Rx frequencies of the repeater to be certain they match the settings in your radio. Also, you will need to be certain your interference code is set to zero (the off position) to be used with the repeater. I didn't read up on the T7200, but if it has a Qt filter, set it to zero also.
Jul 26, 2009 | Motorola Talkabout T7200 (22 Channels)...
WAP54G's as repeaters
Are you trying to setup both access point to repeat the signal of the router?
The correct way to setup the AP's as repeater is to access the setup page of your router go to status and go to the wireless subtab, check what is the MAC address that is what your suppose to configure on the AP's not the LAN MAC address which is on the local networks subtab on status.
Access the setup page of the AP's and go to AP Mode, make sure that you choose the repeater and copy down the Wireless MAC address you obtained from the wireless router. To enable roaming, meaning your wireless computer/device will connect to the AP/router closest to its location, change the wireless channel on all three device for example WRT54G will be on channel 1, 1st AP as repeater on Channel 6 and the last AP to Channel 11 but the other settings must be the same(Wireless name(SSID) and Wireless Security).
Note: Setting up an AP as repeater to repeat or extend the signal of another AP that is set to repeater is not recommended since the signal will deteriorate due to the number of hops the packets will be sent.
Hope this will help you setting up those WAP's which for me is quite useful since you can set it up to act as a repeater, AP client and a bridge to a WRT54G router.
Regards,
Sep 10, 2008 | Linksys Wireless-G WRT54G Router
Ipod nano 2nd generation won't fast forward
Turn repeat off in the menu.
Setting iPod nano to Repeat Songs
You can set iPod nano to repeat a song over and over, or to repeat a sequence of
songs. iPod nano repeats songs within the list you choose to play.
To set iPod nano to repeat songs:
m Choose Settings from the iPod nano main menu.
â To repeat all songs in the list, set Repeat to All.
â To repeat one song over and over, set Repeat to One.
To turn repat off, go to Repeat off.
May 21, 2008 | Apple iPod nano 2nd Generation MP3 Player
I need to know how to reset the time/date on the answering
Hold the repeat button for about 2 seconds. The unit will say Time is not set then Monday 12:00 AM. 'press and hold the on/off button to advance the days. After the day is set,press the repeat button to set the hour. Press the repeat button to set the minutes. After the minutes are set,press the repeat button to set AM or PM. Hope this solves your problem.
Aug 14, 2007 | Conair TAD2018CG Digital Answering Machine
Zyxel Communications 300 Mbps Wireless N Gigabit Firewall VPN Router (VFG6005n Logo
77 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
