The machines is saying nf - Washing Machines
    Master:
  • 818 Answers
Nf means no fill-make sure you have an unrestricted water supply pressure-colgged or pinched hoses can make this happen-cheers Denny
Posted on Oct 18, 2013
MAYTAG NEPTUNE WITH NF SYMBOL
Symbol - 'Washer has tried to fill' Check water faucets & hoses for kinks. OR call Maytag 1-800-688-9900. Happy Washing!!!!
Nov 02, 2016 | Maytag Washing Machines
FRONT LOAD WASHER samsung model WF338AAW/xaa
you need to sort this part out level sensor located near to the door switch and main board.
samsung boardpng-vn1wiordb5lxotmqu1or3lil-1-4.png wiring will be similar to this. might have a blocked air feed from the drum don't blow into the sensor take the clear pipe off and blow down that to make sure its not blocked, washing powered and stuff can block the line.
Jan 13, 2018 | Washing Machines
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
What does nf mean
NF stands for no fill, which means you are not getting any water into the machine. This is either because the water valve has failed or is clogged, the water is turned off or the pressure switch thinks there is already water in the machine but the last is very unlikely.
Jun 22, 2012 | Maytag Neptune MAH6500A Front Load Washer
HOW TO FIX NF CODE IN MAYTAG WASHING MACHINE
Hello & Welcome to FixYa
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
What the heck does nd stand for? Why does it sometimes say nf? Model MAH5500BWW
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump.
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to, nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
May 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have an error code that says nf
NF error in your washer is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Mar 06, 2011 | Samsung WF337AA Front Load Washer
What does nf mean?
NF = Not Full
Is displayed when machine does not fill with water in the allowed time. Could be low water pressure at the feed pipe. Could be dirt clogging the inlet hose screen. Could be that the faucet valve is not fully opened.
Let us know of your success!!
Oct 12, 2009 | Samsung WF337AA Front Load Washer
Maytag Neptune Top Load Washer - Rinse Cycle won't run - Machine says nF
Sounds like the 'Wash water' is not pumping out fully,You need to drain the water by lowering the empty hose into a bowl & check the pump for a blockage ( if the pump is an 'electric one' check that it is working). TURN POWER OFF FIRST
Oct 25, 2007 | Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
