Question about KitchenAid KUDE70FXSS Builtin Dishwasher
Flashing clean light - KitchenAid KUDE70FXSS Builtin Dishwasher
Flashing clean and heat light?
Sounds like you might have lint build up. Clean out lint trap and remove the back and clean out all lint. The lint build up could be causing a over heating problem. And this is a fire hazard.
Aug 08, 2015 | Whirlpool Dishwashers
Flashing red flight
Its probably the cleaning light that comes on periodically to remind you to clean the unit. Shut off the unit AND when you do so hold down the power button for several seconds until the flashing red light shuts off. The cleaning light should stay off until the next cleaning is due.
Per the Air-O-Swiss FAQ:
Q: Cleaning light is flashing (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: Switch the unit OFF and unplug it. Empty the water in the base. Rinse the base with hot/clean water. Do not submerge the base! Visually inspect the base for dirt or mineral build up. If soft water is used decalcifying the unit every 4 weeks with EZ Cal is suggested. If hard water is used the unit should be decalcified every 2 weeks. Do not forget to reset the clean light after resetting the unit.
Q: Reset cleaning light (AOS U650, AOS 7135, AOS 7142, AOS 7144, AOS 7147)
A: The cleaning light does not automatically reset. Hold down the power button (button A in instruction manual) until the light stops flashing. The light automatically comes on approximately 14 days after plugging in the unit.
Feb 15, 2014 | Air-O-Swiss U7142 Humidifier
Saeco intuita- performed clac/ clean, and now calc/ clean fast flashes. Pressing only goes to slow flash and water dispensor light fast flashes.
Use a paper clip to clean the Needle that penetrates the Kcup. If it still happens call 1-866-901-2739 for direct assistance.
Dec 29, 2013 | Keurig B60 Coffee Maker
Pilot light not lighting on 420ex speedlite canon flash
This may seem dumb to ask but have you made sure all batteries are fresh (even new ones can be bad), they\'re inserted correctly observing polarity and the contacts are clean in the flash? (You can clean them using a clean, dry pencil eraser and a Q-Tip dipped lightly in alcohol.)
Also, try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Feb 28, 2013 | Canon Speedlite 420EX TTL Flash
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
66515919001 dishwasher doesn't finish washing. clean light flashes
The clean light is flashing due to a fault in heating the water properly. See the link below to reset the control so you can use the dishwasher and what might have caused it. Let me know if this was helpful.
Clean Light Flashing
May 28, 2010 | Kenmore Dishwashers
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Jun 18, 2007 | Whirlpool ACQ158XP Wall/Window Air...
KitchenAid KUDE70FXSS Builtin Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
