Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
I need the part that holds the hose in place when not in use. it is a clamp like plastic at the top by the handle.
    Scholar:
  • 161 Answers
Check out the vacpartswarehouse dot com and type in your model number. They have decent schematics that may help you find your plastic clamp.
www.vacpartswarehouse.com/Bissell-ProHeat-ClearView-Deep-Cleaners-s/545
Posted on Oct 18, 2013
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 10, 2009
Cleaning heater core
The heater is located in the handle. It can become clogged with soap or mineral deposits. It can be removed and cleaned by removing the screws holding the front and back of the handle together. Separate the handle parts to gain access to the heater. It can be removed by taking the clamps off the water inlet and outlet lines. Remove the electric wires from the heater. Remove the screws holding the top on the water heater (be careful not to lose little gaskets with each *****) clean inside of heater and reinstall all wires, hoses, screws exactly as they were before.
Mar 29, 2016 | Bissell 8910 ProHeat Clear View Upright...
Top coupler on gas pump handle ONLY (Majestic 360 SS) is broken. Do we have to replace whole hose and handle assembly?
They now make a replacement tab so you don't have to replace the entire handle grip. The bad part is, most of the time it's the handle grip that has the broken place in the plastic, not the latch tab. That too can be bought seperately though, so you don't have to buy the hose. Call your local vac shop for assistance.
Oct 21, 2014 | Filter Queen Majestic Canister Vacuum
Hoover steam vac hose is broken
This applies to Hoover SteamVac model F5899-910.
My unit had a broken hose. I repaired the hose using duct tape and Teflon tape. The breakage seems to be due to a manufacturing error or design defect. The hose is clamped to the unit where it passes to the inside. The position of the clamp did not allow enough slack when the handle is released and the unit is wide open.
The hose coupling has a plastic latch that holds it onto the vacuum nipple. Pry it and remove the coupling. Then trim the ragged end of the hose and clean things up. Wrap the hose with some teflon tape and then tape the hose to the coupling with several turns of duct tape. Attach the hose coupling back onto the vacuum nipple.
Now you should move the clamp say an inch, so that it leaves more slack. Take the two screws out of the clamp and pry out the plastic bracket/cover that holds the clamp in place. Then move the clamp and screw the clamp back onto the bracket/cover. Then snap the bracket/cover back in place.
Take care not to put too much slack in the hose (by moving the clamp too far), as the hose can also bunch up due to being too crowded when the handle is upright.
Inspect the hose and the tape whenever you use it.
Aug 03, 2012 | Hoover F5899-910 SteamVac Vacuum
I have a Dyson Animal vacuum. My wife removed the handle to use some of the attachments for cleaning. When placing the handle back to the vacuum, she attached the top part of the handle back to the...
Sorry to hear you're having difficulties with your DC07 Animal. From what you've described, it sounds as if the wand has been replaced on the cleaner without the hose being retracted. To remove the wand from the machine, hold the cleaner securely in place by placing one foot on the cleaner head, then pull the wand up forcefully whilst holding the purple quick-draw hose release (located above the on/off switch) down. Make sure you are not leaning over the top of the wand as you do this.
Once you've freed the wand from the cleaner, make sure you retract the wand before replacing it on the cleaner again. Hold down the hose release button on the hose cuff as you retract the wand inside the hose.
You might find it useful to refer to the user guide supplied with the cleaner - in case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If you have any further queries about using or maintaining your Dyson cleaner, please call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need. Alternatively, you can resolve many issues without picking up the phone by visiting www.dyson.com and clicking 'Support'.
Kind regards,
Jack
Dyson Online Customer Support
Aug 28, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do you open a hoover steamvac agility to change the lower hose assembly?
ok. you will need a screwdriver phillips and a pair of ****. this is going to take about an hour. first take off the tanks, nexted on one side of the machine you will see i believe its 8 to 10 screws. (you don't need to take apart the handle) once you take all of them out, there's a plastic plate that the tanks sit on. take this off. (4 screws) got that done, seperate the two pieces.(the handle will come out so you have more space, it will be a tight fix) the haves are apart and you will see the hoses there. take out the big long hose(2 screws hold it on at the top) and at the bottom of this is the short hose that you need to replace. using your **** cut the plastic on either side of the notches on both sides. put the new hose on. then reverse your steps for putting back together. hope this helps out
Jul 18, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Remove hose from handle on old electrolux canister
BE careful here. Do not fish a coat hanger in the handle.
The original hose has a set of detachable handle componnets.There are two metal screws in the underside of the hand grip.Do Not pry. Once removed go to the suction dial area underside of the grip. Observe the plastic fingers near the dial. These must be reset in their " track " when reassembling the handle.
Gently insert a small flat screwdriver between the rubber wiring contacts and the plastic tongue wraps around the socket. this tongue which extends from the hose handle adjacent to the metal tube. Work you way back to the hose area carefully separating the "hand grip cover" from the hose handle itself.
Once apart remove the obstruction. Carefully clean the two brass rings looking for any pitting. If pitted, gently polish by rotating fine wet/dry sandpaper around the rings, then lube with vaseline.
The matching contact fingers on the handgrip cover should be cleaned as well and gently tensioned to put a bit more presusre on the contact rings.
Slide the handle ONLY onto the hose. Once in place the contact rings will be visible. Now you can work the handgrip cover back into place starting with the two tabs at the hose end below the contact rings. To seat the small fingers at the control valve gently click into place before reinstalling upper handle screws.
Jun 15, 2009 | Electrolux Central Vacuum
Electrolux Epic 6500/ handle clip broke....
The clip can be replaced by taking apart the handle. Small round plastic inserts cover up the screws that hold the handle together. Use a very small screwdriver to pry them off, then use a small screwdriver to remove the screws(Some of the screws may be star screws requiring a special screwdriver. The top part of the handle will then lift off and you will be able to change out the clip. Before reasembling the handle, clean the contacts which attach to the hose and be careful that you do not bend the contacts. It is kind of tricky to put back together.
Good Luck
Captaintek
Mar 26, 2009 | Electrolux Epic 6500 Vacuum
Cracked hose for Bissell SpotBot
I found a site that carrys them, not sure if they are out because just as I was about to order one I decided to try and fix mine since the crack was right up next to the handle. http://www.svcvacuum.com/bissell/steamer_hose.htm
All I did was unscrew the two screws where the button is for releasing the water on the hand piece. I thin squeezed the clamp together to remove the water hose. Once that was removed I cut the hose and then PRYED out the part of the hose in the hand piece. I then cut the hose down where the crack was. Feed the "water hose" back through the hole in the handle (I heated it with a lighter just a tiny bit to make it soft and worked it through the hole which I just enlarged a slight bit) and with pliers work it back on. Don't forget the clamp. Next just work the outter hose back into the handle but make sure to use a glue or silicone sealer or both.
Even if you get a new hose Im not sure it will come with the handle. To connect the hose to the Machine part just push in that little plastic "dot" and pull out the hose at the same time. Then remove the old hose by the directions above. There is no need to remover the inner clear hose from the machine part, only the handle
Jan 17, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 | Vacuums
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
32 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
