Question about Apple iPod touch
I touch malfunction how to reset it - Apple iPod touch
To reset your iPod, you will need a computer with iTunes installed. Connect the device to the computer then open iTunes and select the iPod. Click the restore button to reset the device.
Hope that helps!
Posted on Nov 06, 2013
My Triumph Street Triple displayed the ECU malfunction light after a flat battery which has since been satisfactorily charged. How can I reset the ECU so my bike doesn't remain in limp home mo
You could try the 12 minute tune which I think is appl;icable to this model.This resets most issues.
Start the bike from cold...do not touch throttle then wait til fan comes on then time 12 minutes exactly then turn bike off.If this dont work go to a dealer so they can plug into the ECU and find out the cause..
Sep 17, 2014 | 2013 Triumph Street Triple
C4501 in c451
Laser malfunction; try to reset the equipment as follow:
Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed; keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below. Restart it normally and it should work.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Office Equipment & Supplies
EEE3 Error
Engine section undefined malfunction.Check the printer control board connectors.Try to reset : Turn OFF,press and keep pressed the Utility key and turn ON,kepp pressed Utility and wait while Trouble reset message appeire on scren,release the key,touch the message,turn OFF afetr 1 minute turn ON.
Jul 23, 2014 | Konica Minolta bizhub Office Equipment &...
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn On the copier.
Keep pressed the Utility key and wait while Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 19, 2013 | OCE 3140 Copier
Code malfunctios c1441 minolta di 450
The copiers CPU is equipped with a self diagnostics function that on detecting a malfunction,gives the corresponding malfunction code on the touch panel.Resetting a malfunction:
- Press the trouble reset switch on the technical representative setting switches board to reset fusing and exposure lamp related malfunctions.(code: C400,410,420-expo;C500,510,520-fusing unit)
- For any other malfunctions,open and close the front door or turn OFF and ON the power switch.
C1441 CCD failure(clamp adjustment failure).
Reset the malfunction,check that the original glass is properly installed.Check for extraneous light and check to see if CCD Assy and mirrors are installed at the correct position.If the same malfunction is detected again,change image processing board.
Aug 14, 2012 | Office Equipment & Supplies
C0500 error code
Verify the continuiti of the thermofuse and the heater lamp,cleaning it reset the malfunction codes to open /close the front door or enter in the service code Stop-00-Stop-01,acces 3 after appaire the * in the left side in the touch pannel,reset to trouble icons,press exit and total reset button twice.
Dec 07, 2009 | Konica Minolta DiALTA Di200 Copier
Motorokr touch screen malfunction
choose that master reset on setting wizard,,
dont do again anything with that screen calibaration,,,
Dec 20, 2008 | Motorola Mobility ROKR E6 Smartphone
My motorola e6 touch screen function is giving problems.it is kind of malfunction like wen i touch the message button the option below it opens which shows the battery meter.wenever i touch a button the...
hey its simple,
the same prob was in my fone,
u jst go to settings n click on that master reset,,
u should know dat this prob is due to incorrect touch in that screen calibration,,,
dont do anything with that screen calibaration,,,
Minolta dialta di250
The C0048 error code not exist.Malfunction resetting procedure:
Turn OFF,then ON the power switch or open and close the side cover for all malfunctions except C05XX codes.
Use Trouble reset of the Initial screen to reset all malfunctions.
To right side the touch panel(screen display)near display contrast button exist a little hole (reset switch).Insert a hairpin to touch the switch.
Enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screen being displayed.Touch TROUBLE RESET,and EXIT to go back to the basic screen.
May 07, 2008 | Minolta DiALTA Di520 Laser Printer
Apple iPod touch Logo
21 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
