Question about Yamaha RX-V371 A/V Receiver
Yamaha receiver to the television cable says "decoder off." Called cable company and reset everything, but still does not work
3 Suggested Answers
quang123
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
  • 4 Answers
SOURCE: tv speaker noise from yamaha rx-v663 hdmi connection
try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Posted on Feb 23, 2009
How do I hook up my digital cable to my ilo flat screen TV with out a box
It won't work because the tuner from your ilo TV will not be able to decode the digital signal from the cable company even if your TV has a digital tuner. The digital tuner on your TV will only decode over the air signals.
You will still need the digital cable box from the cable company.
Aug 03, 2015 | iLO Televison & Video
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
I cannot figure out how to get sound through my Yamaha RX-V361 from my LG 37CS56 hdtv
Are you using any kind of Decoder or Set Top box to receive your TV signal?
If so you can connect the RCA OUTPUT from your cable or satellite decoder, to the Yamaha inputs. See the picture I have attached for you.
Then when you want to hear the sound from there, select DTV /CBL input on your remote control of the Yamaha receiver.
Or you can locate the SOUND or AV OUTPUT (Red and white RCA connection) at the back of you TV, and connect the cables from there to your Yamaha receiver.9_9_2012_6_50_32_pm.jpg
Sep 09, 2012 | Yamaha RX-V361 Home Theater Receiver
My RX-V665 receiver lost its sound for no apparent reason while we were watching a show. It was in HDMI mode and has the message "Decoder Off". The sound works with a DVD and a CD, just not...
It's telling you the digital decoder is now "off" and will treat everything like 5.1. THAT is a selection you choose, not a status that spontaneously appears. Perhaps someone unknowingly touched the remote while playing.
Get the manual out and read up on DECODER. Page 61 (Troubleshooting: NO SOUND) suggests "A proper audio decoder is not selected". Try AUTO.
Or, track the digital source of your TV audio back to make sure it still works.
Jun 15, 2011 | Yamaha RX-V665 Receiver
I have hooked up my dish, yamaha receiver, CD player, blueray player and have surround sound for everything but the TV, Help!
Usually, unless the TV show is being broadcast itself in surround sound, the surround decoder in the receiver will default to front only sound on TV shows. When a TV show says that it is in surround sound, the receiver will decode it. I think the Law and Order series in broadcast in surround.
Hope this helps,
Best, Mark
Dec 30, 2010 | Yamaha RX-V463 Receiver
The sylvania plasma tv does not have a coaxial cable connection, how do I connect my local cable?
You just can't. Not without an external receiver.
Your TV is simply missing a piece of hardware - it is called TUNER - that can understand the signal that runs through the cable (or an antenna) and decode it into simple video signal.
So the only solution is to buy an EXTERNAL TUNER device (also called external receiver or external set top TV box).
Those are rather cheap compared with what they used to be, but if you care for an advice from professional it is: sell your TV and use the revenue towards the purchase of a new one. All TVs currently in the mainstream sales channels have that thing built-in.
Some of the older models that you will find on Craigslist (like yours) do not.
it is usually not a problem for users with cable TV because most cable TV boxes also have a built-in tuner. If you are talking about how to connect your TV to your local cable company then the right thing to do is call your cable operator and tell them you want a newer receiver that outputs standard composite (one yellow one red one white) or component (green, blue, yellow and white and red) - if your TV has the later.
Hope this helps. If it does please rate accordingly.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Tv speaker noise from yamaha rx-v663 hdmi connection
Jan 19, 2009 | Yamaha RX-V663 Receiver
Cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Open Questions:
See all Yamaha RX-V371 A/V Receiver Questions
Yamaha RX-V371 A/V Receiver Logo
19 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
