Question about Panasonic DP-3030 Grayscale Copier
I need to replace the front base plate on a sebo BS36 Comfort
Can't get the Sebo S-class filtration off to replace it. I bent the wire down, didn't move much. I tried to pull it off but, it didn't budge.
The filtration cone just pulls out. That's why there's a looped piece of plastic on it at the base of it. The spring wire keeps it in place so that the door can be locked back on.
Aug 27, 2015 | Sebo X4 Bagged Upright Vacuum
How do I replace the front bottom plate on my Sebo X4 Extra vacuum cleaner, this is the metal/plastic plate on the front base of the bottom of the cleaner (no visible fixings)
With the power head cover removed, you will see tabs on the inside of the chassis inline with the front bottom plate. Simply pinch the tabs with some needle nose pliers and push. I have included a link to the parts list as well as the front bottom plate. You will see by the picture what those tabs look like and how to remove the front bottom plate. 5411 HG Front Bottom Plate Windsor Sensor S12 XP12 SR12 86138280 allstar... http://sebo.us/pdfs/website_schematicsPDFs/AUTOMATIC%20X%20Schematics.pdf
Dec 09, 2014 | Sebo X4 Extra Bagged Upright Vacuum
My 1 Year Old Sebo X4 was lowering itself to hardwood floor with no air gap. Sebo Support agreed with my repair shop that a new (blue) brush roller would fix the problem by replacing the 'worn" brush (same...
No not quite. For a start, the stiff bristles on the blue roller can last a few years before requiring to be replaced.
The SEBO sensor wheel adjusts to the height required - unless of course the microchip board has been tampered with. If it hasn't been tampered with. If the central wheel is excessively dirty then it could be that the SEBO isn't lowering the height properly. However, the X series is great at cleaning hard floors in general - i it is not designed for the brush roll to fully hit the floor, thus as you suggest crushing the bristles. It is designed, as you recognise quite correctly to skid across a hard floor lightly as there is a squeegee rubber strip built in at the back of the roller bar that scoops all dirt into the central vacuum path. The front plate also lends this job. You are not being conned - however check that the rubber squeegee strip has not worn away - SEBO do sell the strips and they are easy to slide into via the press release door at the side of the brush roll.
If the SEBO has died then its a possibility that there is a microchip function that gone wrong it. Some more information would be good to know here as it could be a number of things such as the cord cables coming away at the handle.
Oct 30, 2013 | Vacuums
Hi. I have a Sebo X1 about 12 years old. Last time I used it there was an unpleasant smell in the room but didn't seem to be coming from the Sebo. However I am now trying to use it and it doesn't work. The...
The unpleasant smell could have been the lifetime belt finally giving up. Also happened on our 13 year SEBO X1 Automatic due to my error of vacuuming up a rug with long loose strands! If you are good with a screwdriver, you can replace the drive belt easily enough - go onto You Tube - there is an excellent UK video showing how to replace the drive belt on the SEBO. There are two belts, but you will know which one has to be replaced if you remove the screws on the underside of the main floor head. Before you do anything, kneel on the floor beside the SEBO and press the main release button on the bottom of the front bin area just above the floor head. It may need brute force but when pressed, put on knee on the floor head gently and pull the bin upwards to release from the body of the SEBO. This unlocks the main floor head from the bin, making it easier to look at the floor head. See video: http://www.youtube.com/watch?v=AOPphVcZHYA
Sep 14, 2013 | Sebo Vacuums
I need to know how to repalce the drive belt in a Sebo upright cl
Thanks to its automatic height-adjust feature, the Sebo X4 has two drive belts, one from the motor to the height-adjust sensor, and another from that sensor to the brush roller. To access them,first remove the base from the handle, undo the four recessed screws on the underside of the base, then turn it over and lift off the cover. You will then see the belts. The rest should be obvious (it's a while since I've done one of these, but I think you may have to loosen the screws holding the height-adjust sensor before you can slip the belt off).
I hope this helps. Any further problem, just re-post here and I'll do my best. Good luck!
Feb 01, 2009 | Sebo Air belt K3 Bagged Canister Vacuum
Sebo automatic x1.1 loss of suction
Check that the dust channel from the sole plate/brush head isn't clogged. Open the trapdoor (usually orange in colour on the base) and inspect the dust channel - sometimes dog hair can get trapped between the main dust channel and the feeder. Other than that take off the main hose and see if there's a clog down there as well as the main part where the wand locks in at the back. Its reasonably easy to get a clog out from a Sebo X range model.
Jan 16, 2009 | Vacuums
The Clog light is on my Sebo Essential G1 vacuum
If you are sure the base is clear, and that the flexible hose and attachment tube are clear, the only other common place for a blockage is the swivel neck that joins the base to the bottom of the dust bag housing.  Here's what to do:
Press the housing release button (front bottom of bag housing) and lift off the bag housing from the base. This can be quite hard (three or four hands would be helpful) but be sure to lift straight. When you've got the bag housing off, release the foot pedal and lower the swivel neck to 45 degrees.  Check inside the swivel neck channel closest to the foot pedal, and clean it out as necessary.
If this doesn't work, please post again and I'll see what else I can do...  If it does help, please rate me!
Nov 27, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
How do I change the flilter on the sebo upright
Depends on the filter you're talking about:
The first filter is in the bag area- unhook and lift off the bin door, then bend down and flick your finger onto the left hand spring that locks the long cylindrical felt filter in place and lift upwards - this will loosen and unlock the filter from the base - put your hand at the back or front of the filter at the front near the base and pull towards you - the filter should then slide off easily.
Or it could be the motor filter you are referring to; push the pedal all the way down on the pedal release to put the X1/X1.1/X4/X5 into the lay-flat cleaning position, and push back the grille on top of the hood - you'll see a push finger mechanism there of which the grille will then be unlocked and can be picked up.
Nov 11, 2008 | Sebo X4 Bagged Upright Vacuum
Windsor sensor sr12
There is a downloadable manual from http://www.windsorind.com/ go to documents, and note it is in alphabetical order -- so page through to "sensor" or you can search on the word "sensor" (don't include SR12). Also excellent training video on youtube http://www.youtube.com/watch?v=ikhtNFEKpeg.
I think, but not validated yet, that the Sensor SR12 (residential model) has been discontinued as I found it listed in their manuals under the discontinued section as well.
Jan 28, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
Evenflo front facing car seat
To adjust the height of the hanress you will need to turn the seat around and locate two metal, rectangular plates. These plates are attached to the harness straps and should attached with plastic tabs. you will need to remove the plate in order to change the harness height. To do so, you may need a screwdriver to loosen the tab enough to release the plate. When removed, feed the plates back through the front of the seat through the predetermined slots. Reroute the plates through the appropriate holes in the seat that best fit your child.
Jul 05, 2007 | Evenflo Chase Comfort Touch
Panasonic DP-3030 Grayscale Copier Logo
26 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
