Question about Denpa USB-24 Digital Voice Recorder
Converter harbinger - Denpa USB-24 Digital Voice Recorder
Harbinger ha120 no sound to speakers. What's wrong?
It could be a number of things. Does the head light up when turned on? Are the controls on the channel turned up? Is the master turned up? Have you checked continuity on the cables? Have you tried the speakers with another amp, or the amp with other speakers? This will help narrow down the problem.
Sep 21, 2015 | Harbinger Music
Why does my harbinger aps15 speaker keep blowing fuses when powered up.
probably shorted the integrated amp chip...they are not worth the trouble to fix..buy some good equipment.
Sep 20, 2014 | Harbinger APS 15 Powered PA Speaker
I need a user manual for this product
enter: harbinger ha1000 powered mixer manual in the google search bar and it is the third item.
Aug 17, 2013 | Harbinger HA1000 Powered Mixer
Harbinger APS 15 has a broken horn
Where can I buy a horn for my speaker?
Jun 19, 2012 | Harbinger APS 15 Powered PA Speaker
Yeasterday i was cleaning my room while playing the harbinger APS15 with my laptop, and all of a sudden the word weren't as loud and all i heard was more bass on the song. how can this be fixed ?
It is possible the tweeter prtion of the APS15 has failed. Try a different audio source such as a CD player to verify which part is bad, the speaker or laptop.
Dec 20, 2010 | Behringer Xenyx X2442USB / Harbinger...
Harbinger Decoder
Okay, I'll try and help you out...
1. Create new folder on desktop called 'recordings' or something similar i.e. easy to remember!
2. Connect unit to PC via USB cable and turn on the unit. If you slide the HOLD switch to the on position, you should get a message saying "PC LINK" on the display.
3. Locate the recording(s) that you want to decode. I don't know what model of denpa you have, so I can't be sure, but there are normally four folders (A, B, C, and D - there may also be an MP3 folder). The recordings are accessed by double-clicking my computer, then the removable disk icon that appeared when you plugged in and turned on, and then opening the folders that are present which contain the recording(s) you wish to decode.
4. Identify the recording(s) you wish to decode and copy them to your newly created desktop folder (right click the file/copy and then go into new folder and paste there).
5. Once you have copied the file(s) you want to decode, open the Converter program (programs - harbinger converter - converter 1.4).
6. In the program window click on the magnifying glass in the top box (source file) and browse to your new folder.
7. Select the file you wish to decode (I think you have to do them one at a time - just repeat the process for each one following these steps).
8. In the lower box (output file) enter the name you wish to use to identify the file so you can find it. Then click on the magnifying glass for the output file and browse to your newly created folder (this will then be where your converted files will be sent on decoding).
9. Click the 'decode' button in the lower left corner of the program window (I think it shows a picture of two different sized cogs side by side).
10. The file should then be decoded from its .hgl format to a (new) .wav format with whatever name you gave it. From here, you should be able to listen to the file on your PC using any common media player (i.e. Winamp/Media Player etc.) or recode it as an .mp3 if you want to save some hard disk space on your computer.
Repeat the process from step 6 for each file you want to decode.
Hope that helps and good luck.
Jun 21, 2007 | Denpa USB-24 Digital Voice Recorder
Denpa USB-24 Digital Voice Recorder Logo
35 people viewed this question
Top Denpa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denpa Audio Player and Recorder Expert? Answer questions, earn points and help others
