Question about Kenmore 96212 / 96214 / 96219 Electric Kitchen Range
Range oven door
I accidentally pressed the "clean" button instead of the "clear" button. Not wanting to clean my oven, I opened the door thinking that would stop the cycle. Wrong! The door lock clicked and now I cannot close my oven door. The lock light blinks and of course, the oven light stays on permanently. I tried unplugging it hoping it would reset. I have tried clearing it, but that doesn't work either. How can I get the lock to unlock?
  • 4 more comments
  • Anonymous Nov 05, 2007
    Door lock is engage with the oven door open. Will not allow the use of oven
  • Anonymous Nov 13, 2007
    I pressed the stop/clear button too long for the oven and the lock light and notice message shows up. How can I get the lock to clear and the light to go out>
  • Anonymous Sep 04, 2008
  • Anonymous Feb 16, 2009
    i need help to set up my door unlock
  • Anonymous Mar 21, 2014
    moved the range to garage while we renovate kitchen Electrician installed range outlet we plugged in everything works but the oven door is locked tried locing and unlocking by holding the start button for 3 seconds but it still will not unlock
  • Anonymous Mar 30, 2014
    Door Lock On
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Try holding the door switch closed and press cancel. that usualy takes care of it. if that doesnt work send your model number out and this will help.
Posted on Sep 27, 2007
6ya staff
SOURCE:
My kenmore 46745 or 46749 (both models listed on the manual) door is jammed. I accidentally opened the oven door, stopping a cleaning cycle after only 15 seconds, and now the door will not close...the lock...
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Nov 26, 2010 | Kenmore 45781 / 45782 / 45784 / 45789...
"Locked Door" flashes after interrupting self clean...
Hi robertkbrown...you may want to try to following steps.....good luck my friend...chris If ?LOC DOOR? is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control: Motorized Switch 1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel. 2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed. 3. While you hold the door jamb switch in this position, complete the following steps. 4. Press the Clean pad, wait 10 seconds. 5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it. 6. Wait 10 seconds for the display to clear. 7. The door should unlock and there should not be a need for service. Manual Switch 1. Press the Clean pad. 2. Close the door. 3. Slide the latch to lock the door. 4. Hit the cancel button immediately. 5. Unlock the door.
Aug 25, 2007 | GE JBP60 Electric Kitchen Range
I think I turned the oven onto the clean when trying to turn the oven off. The door locked after I opened the door and now the door will not close because the latch is in the lock position. How do I get it...
normally pressing the clear/off button for three to five seconds should clear this mode and unlock the latch. you can also try and unplug the unit and press the clear off button
Nov 13, 2010 | Amana ACF4215 Electric Kitchen Range
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Tappan Millenia - oven door locked can't open
how do i open my tappan computerized over when close and won't open
Jun 10, 2008 | Tappan TGF320 Gas Kitchen Range
Locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
May 12, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
"Locked Door" flashes after interrupting self clean (follow up)
Kenmore 96212 / 96214 / 96219 Electric Kitchen Range Logo
321 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
