Question about Philips Accessories SRP4004/27 Glow Keys Universal 4 Device Remote
Cannot set timer record for vcr - Philips Accessories SRP4004/27 Glow Keys Universal 4 Device Remote
Timer mode is locked on vcr
You must have set a timer record. Press the button that sets a timer recording and cancel them. If you have the manual check what it says if you don't have a manual Panasonic do have PDF of most videos free. IF you can't clear try the factory reset opition.
Jan 14, 2013 | Panasonic 4-Head VCR PV-V4525S
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Samsung DVD-4600 won't record with VCR timer set
Press fast forward and rewind button on the unit simultaneously for 10 seconds with no disc inside the player to reset it to factory setting.
Aug 19, 2009 | Samsung Televison & Video
Doesn't give me the option to change the channel when timer recording
If you are recording something on the VCR, it won't let you change the channel. If not, you need to make sure the RC is set to the vcr in question (mine has VCR1 and VCR2)
You can set it up the way I've done for years...put cable line into VCR first, the VCR to TV..you then can watch and record 2 separate channels.
May 09, 2009 | Proscan PSVR73 VHS VCR
VCR not timer recording, VCR will not turn on with timer
If no menu, unplug, and let it set a few minutes. Replug and the on-screen menu should appear. Reset the set-up (date, etc). I had the same experience as one of the other posters with JVC customer service telling me the menu button on the remote was malfunctioning, and I should purchase a new remote from them.
After you input your programming, be sure to hit the Timer button on your remote. If you want to change tapes or playback, you will need to hit the Timer button again (take it off Timer) for access to your VCR. Be sure to reset it to Timer afterwards, or you will not be able to record.
Feb 17, 2009 | JVC HR-A592U S-VHS VCR
Cannot record VCR thru Cable Box
make sure that the cable runs first through the cable box then through the VCR then to the TV.
if you know how to set timers on your cable box (if you have that option), set those in addition to your VCR timer. If you don't have that feature or are not sure, you will, unfortunately, have to keep the cable box on a certain channel before you record.
hope this helps!!
Feb 10, 2009 | Panasonic Televison & Video
Won't timer record
- Does it have a tape inserted?
- Is the clock set?
- Is VCR off? (has to be off to be in timer mode for many VCRs)
- Is it recording but just plays back blank or does it not even start?
- If recording blank, make sure you are giving it a signal (Is your monitor hooked to the VCR output?)
- If timer doesn't start double check timer settings - they can be very tricky.
Nov 06, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
How to set the vcr to record
Hi I'm not familiar with your model in particular, but normally there will be a timer button on the remote that you must press, or you must turn the vcr off after programming it for the timer recordings to be made. There should be a timer indicator on the front, either a symbol or a red light depending on the age of the vcr. If you program it, then press the timer button on the remote, the timer light should be on and the vcr will shut itself off, if it is the other type, then the timer indicator should stay lit when you shut off the machine. If that light is on, then your timer recordings should work. Hope this helps, good luck!
Feb 06, 2007 | Hitachi VTMX4510A S-VHS VCR
Philips Accessories SRP4004/27 Glow Keys Universal 4 Device Remote Logo
20 people viewed this question
Top Philips Accessories Televison & Video Experts
Are you a Philips Accessories Televison and Video Expert? Answer questions, earn points and help others
