Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
Maytag md87749aww2 control buttons don't work
How to reset a Maytag MD87749aww2 dishwasher
The reset is done by disconnecting power to it. If it is under the counter, you need to find the breaker that it is on and shut it off for a minute then turn it back on.
Oct 03, 2013 | Maytag Dishwashers
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
My Maytag Washer won't drain or spin
Inside the main control switch has many studs of plastic. They get worn out and don't work. See if it works on a different cycle like delicate. No work; then you need a new control switch. Either way you need a new control knob switch!
Nov 09, 2012 | Maytag Washing Machines
Maytag PDBL390AWW buttons don't work
you should be able to retrieve the tech spec sheet behind the toe kick panel and it will give you steps to follow to find out which component is defective
Oct 13, 2012 | Maytag Dishwashers
Maytag microwave keypad
see this causes and fix it. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Troubleshoot maytag keypad control board
Oct 01, 2012 | Maytag Appliances Over-the-Range Microwave...
I have a maytag dishwasher model mdbh985aws1that stopped working. The controls buttons on the left light up when pushed but the buttons on the right (including the start button) do not work. Any ideas on...
The CONTROL PANEL and/or ELECTRONIC CONTROL BOARD are broken. Unless you are good with a multimeter and wiring diagram just order both and send back the parts you don't use.
Aug 26, 2012 | Dishwashers
I brought a maytag steam clean with electronic controls. What is happening is that all the controls are working except for the start button. No matter how hard or gently we push the start button it will...
THE PROBLEM IS WITH THE SWITCH ITSELF AND REQUIRES SERVICING . WHY NOT CHECK IF THE MACHINE IS STILL UNDER WARRANTY .AS IT IS A ELECTRONIC CONTROL IT MIGHT COST YOU A BIT.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | Maytag Dishwashers
I have a maytag model #MSD2651HEW and the problem is that the control features is lock and I can't unlock it. I press and hold the lock/unlock button for three till five seconds and it still...
Hello, Thank You for using FixYa. I will be helping you today.Try to unplug the unit for fifteen minutes sometimes it will clear it.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag MSD2655HE Side by Side Refrigerator
Only some of the keys on the keypad of my oven work. I have replaced the control board (computer board), but they keys still don't work. What specific part do I need to replace?
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Jun 10, 2011 | Maytag MEW6530DDS Stainless Steel Electric...
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
122 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Colin Stickland
Colin Stickland
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
