Question about Ovens
AKZM 755/IX whirlpool oven, Simply the Grill (Top Element) comes on without even switching on the oven and stays on reaching crazy temperatures and not switching off. Seems like not control and comes on when switched on from Mains. Please help
  • 4 Answers
SOURCE: Grill problem
YOUR PROBLEM IS WITH THE GRILL SELECTOR SWITCH REPLACING THIS WILL CURE YOUR PROBLEM.
Posted on Feb 14, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 18 Answers
    SOURCE: Stoves 720EF Top Oven Failed
    there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
    Posted on Jan 23, 2009
    • 291 Answers
    SOURCE: Oven doesn't reach temperature setting
    It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
    Posted on Aug 31, 2009
    • 523 Answers
    SOURCE: GE Wall Oven won't hold temperature and sometimes shuts off
    t stat
    Posted on May 27, 2010
    I have whirlpool oven akz451/ix/01. My element is square when I look for a new one they are all round ?? Will this work in my cooker ??
    whirlpool service center /agent will have a correct element for your unit
    the shape is probably for a more even heat distribution in the oven as it will cover the floor/ top area of the oven better
    Nov 30, 2016 | Whirlpool Ovens
    Ignis AXL 905/IX oven and prob is food is cooking on top but not below. Two elements at top. Inner on when in oven mode, outer on in grill . Bottom of oven not warming evenly and burning top of food
    Your bottom element is not working and that is why foods placed on top heat up but the undersides are not affected as much.
    You need even heat on both sides of the food. Get a new element and replace.
    Sep 06, 2015 | Ovens
    I FITTED A NEW ELEMENT IN THE OVEN,BUT NOW EVEN THE LIGHT DOES NOT COME ON.IHAD THE NEW ELEMENT CHECKED AND THAT IS WORKING.THE SWITCH IS CLICKING FINE WHEN I TURN IT ON AND OFF.I CHECKED THE BULB AN
    I know this sounds crazy but check your breaker then if it is not the breaker something went wrong when you installed the Element
    Sep 21, 2014 | Ovens
    Hi, It looks as if my heating element on my AKZ446/IX oven has gone, as the fan, oven and grill work fine but no heat come out from the oven. I've seen on the online videos how to change the heating...
    NEmmake sure you removed the correct item first
    replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
    Jan 26, 2011 | Whirlpool AKZ159IX Oven
    The top oven of our AEG D5701-4 is slow to heat.
    Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
    Mar 09, 2010 | AEG D5701-4 Electric Double Oven
    Whirlpool - akz451/ix/01 - Fan oven blowing out cold air
    could be a blown element if not it could be a safety cut out or the stat
    May 17, 2009 | Whirlpool AKZ159IX Oven
    Whirlpool built-in single oven AKZ451/IX/01
    If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
    If not the case, is this gas or electric?
    Nov 11, 2007 | Ovens
    Ovens Logo
    108 people viewed this question
    Top Ovens Experts
    ashburton
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
