Washer stops mid cycle
Washer will stop washing in mid cycle. Sometimes I can get it to start again by raising the lid and then dropping it down hard. However, it is getting more difficult to make this work. I heard this could be a fuse problem? Any thoughts? thanks.
  • 1 more comment
  • Anonymous May 16, 2008
    Washer stops working mid cycle and the only way to get it going again is to push down on the lid. It also stops at more than one point.
  • Anonymous Mar 08, 2009
    I bought a new lid switch... but how do I install it?
  • Anonymous May 23, 2009
    How do you replace the lid switch?
Relace the lid swich ! it may sound simple but it can be a pain to get to , this should solve your problem though!
Posted on Feb 19, 2008
  • 3 Answers
I had this same problem, it was the lid switch on the left side of the lid that was causing the problem. It seems to be designed to stop the washer if the load becomes too unbalanced. I ended up taking off the control panel and looking at the switch. The problem switch is a two part brass metal switch, the two parts are connected by a spring. It appears that the join at the spring started to work itself loose easier as I used the washer more. I ended up putting a twist tie around this join (through the square hole and around the part that descends vertically into the washer), and tightening it up well so that the two brass parts would stay connected and not release apart so easily. It seems to have worked well, I haven't had this problem re-appear at all.
The one thing that I am careful of now is the load balance of my washer. Since my 'repair' in effect bypassed the load imbalance mechanism of the washer, I am more careful of how much I put into the washer.
Other than this hiccup, I'm quite happy with this little washer and how well it has performed. Great value for the money!
Posted on Dec 22, 2007
  • 447 Answers
Lid switch
Posted on Sep 27, 2007
6ya staff
SOURCE:
GE WBSE3120 Washer stops mid cycle
if it makes a grinding sound when in spin this is the tub seals or bearing and basically you'll have to replace the washer.very common with this ge washer,not one of ge's best product,also why it stops mid cycle could be anything,this washer has a computer board biult on top of the motor that also failed,if your having all these issues i think that washer sold for like 500 dollars,it would cost more just to repair it,i wouldn't put 5 cents into it,do yourself a favor and get a new washer.
Dec 04, 2017 | GE Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer has been stopping mid-cycle like the lid was opened lately. I have been able to open and close the lid to "jar" it into finishing the cycle(rinsing) until now. It has just stopped and...
The lid switch will need a slight adjustment to properly activate, or you could bend the raised bump on the back of the lid out a bit so it activates the switch better.
Jul 27, 2011 | Maytag Washing Machines
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
Whirlpool washer spin cycle works off and on
no the slowing down maybe caused by a sticking clutch and as before the lid switch may also be broken if when you depress it the reason i'll give is if you bump it it sometimes starts up replace the lid switch and once done the circiut will close properly then the delicate cyc should work
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
[email protected]
Aug 21, 2009 | Kenmore Washing Machines
Washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine timer stops mid cycle
Your lid switch needs replacing.
Part number 3949237 available at any applinace parts store.
Apr 05, 2009 | Estate TAWS800JQ Top Load Washer
Whirlpool washer stops for no reason.
i would be concerned teh the door/lid switch is not being activated, or is loosing contact withthe swtch mid wash causing unit to shut off. unitll the lid is lifted and closed to make better contact.. tyhe activator for the lid switch is actually the underside of the lefthand lid hinge. so if your able toreah under the lid while open you feel the metal lever, as you push and pull hte lid youll feel the lever move as well. with a hollow shafted screwdriver/1/4 nutdriver. place the driver over the metallever andslightly bend it toward the rear of the uni, so it makes better contact with the switch mounted tothe underside of the main top assembly
Nov 20, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
873 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
