Tv wont turn on
RCA big screen tv (and older model) wont turn on. there is a ticking noise behind it that goes away when you unplug the tv.
  • 1 more comment
  • TP13 Dec 11, 2007
    My TV was on during a power failure to the house. When the electricity came back on the TV would not, either using the remote control or the on/off switch on the TV. When plugged in I can here a ticking sound coming from the TV, which stops when I un plug it.
  • mytele Feb 11, 2008
    as soon as the tv is plug in this sound coming from one of the transformers
    there is no picture or sound .
    sound goes away when tv is unplug, if the transformer is the problem where could i order this part.......
  • Anonymous Mar 24, 2014
    noise started about 6 hours after would not turn on. RCA older model. like a drumbeat.
  • 790 Answers
You have defective horizontal output replace a new one H out.
Posted on Sep 28, 2007
SOURCE:
Ticking behind glovebox
Does it sound like the noise the turn signal makes? Does the noise change if you change the speed of the blower motor? Do all the function of the heater work (defrost, vent, floor, recirculate, fresh air, hot, cold)?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 29, 2012 | 2003 Pontiac Sunfire
50 in philips plasma tv
what kind of noise is it ,ok if the power is in and its not turning on it could be a fuse inside blown or even the conveyance board
Sep 11, 2008 | Televison & Video
I need a new screen protector for my older RCA big screen TV
I have a screen protector from a 1998 RCA older model big box style tv
Mar 15, 2010 | RCA P56930BL 56" Rear Projection...
Big black block in the middle of tv
Check youron screen menu setting for Closed Caption (CC) and turn it off.
Oct 29, 2009 | Philips Magnavox 27MS343S 27" TV
Y rca 27f500tdv tv high pitched noise
Change the horizontal IC are damaged
Jul 28, 2009 | Televison & Video
Rca big screen model # P52939
I had same problem on rca big screen M #p46734ba it was hi voltage splitter the part # for mine is 40431-090 GE/RCA splitter it was $36. online
Mar 12, 2009 | RCA Televison & Video
My tv want come on;
If your set is rear projection set you have a bad flyback transfromer or high voltage trippler is bad .
Jan 26, 2008 | RCA P52928 52" Rear Projection Television
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
High Pitched noise returns after new parts installed.
Use first quality OEM or equiv. transistor, RCA 237470 is
least expensive...............T.
Nov 09, 2007 | RCA F36705 36" TV
High Pitched Ticking Noise
Horizontal output transistor is shorted,caused by bad flyback
transformer.If you want to pursue the repair,please give the
service number off back......I will get part # s........T.
Oct 25, 2007 | RCA F36705 36" TV
Televison & Video Logo
333 people viewed this question
Top Televison & Video Experts
Ekse
