Question about Saws
How do I fit a new roller assembly in a gst 60 pbe jigsaw, thanks
SOURCE: how to change blade on bosch jigsaw GST 80 PBE
I just bought a used one and faced the same problem. What I found in there is a set screw at the bottom of the long shaft. I used a long narrow flat head screw driver. It worked good, but I did have to acuate the trigger to get it the blade near the top of the stroke
Hope that helps.
AG
Porsgrunn Norway
Posted on Aug 15, 2009
RonPark
  • 855 Answers
SOURCE: I need a replacement roller part for my Makita 4320 jigsaw
You can go to ToolPartsDirect.com or eReplacementParts.com
Both sites have a listing and a blow up diagram of your saw. So check there if the part is not on the diagram you may be able to call them and there may be a universal one or the right one available. They were the two most promising sites I could find.
Posted on Oct 23, 2009
Testimonial: "Thanks for the advice The only problem is they don't ship outside the US I'm in Australia"
  • 142 Answers
SOURCE: recently purchased a Bosch GST
Depends what do you mean by "rather".
If it can be kept a hand on it, it may be normal, as the knife is getting rather warmer, when used 1 - 2 minutes.
After 1-2 min you should let it rest for about 3-5 min.
Posted on Jun 15, 2010
SOURCE: Changing the blade on my Bosch GST 2000
lift knob on top twist 3 times anti clockwise remove blade by twisting it 90 deg insert new blade turn 90 deg,turn knob on top clockwise until it clicks press down and you are ready to go
Posted on Jul 01, 2010
farmerbear
  • 490 Answers
SOURCE: Manual for Bosch GST 85PE
You betcha, got it right here:
http://mdm.boschwebservices.com/MDMCache/English%20[US]//t10/0000000/r00058v-1.pdf
Thanks for using FixYa.com
Farmerbear
Posted on Sep 09, 2010
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
Cant find serial number on my bosch gst 150 bce jigsaw
Contact Bosch tech support by phone, they are usually very helpful.
Nov 07, 2013 | Tools & Hardware - Others
Manual for Bosch GST 85PE Jigsaw
Farmerbear
Sep 08, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
I have an HP Laserjet 5mn printer. I started getting papers jams from the printer the other day. It now jams all the time. The jam is located at the fuser rollers. I noticed that the lower rubber roller...
If the paper is jamming like an accordian (sp?) effect, then the output roller assembly needs to be replaced. If its jamming at the fuser assembly, you probably have a bad gear or worn out roller. Since the unit is really old, your best bet is to replace the whole fuser assembly. You could probably do this yourself, and the fuser would be approx. $40 - $95.
if its the output assembly, I would really recommend taking it to a service center, the output assembly would be approx. $45-$55 plus $40-60 for labor. If you want to do it, you will need to take out the 2 screws in the back and the 2 screws on the top (left and right) to take out the top cover. Be careful with the cable, pull it out. The output assembly has 2 plastic indents that you push inward, and flip the assembly outword and pull up. When putting the new one in, make sure the notches go into the bottom frame.
thanks, and I hope this helps.
Jun 17, 2010 | HP LaserJet 5m Printer
Oct 22, 2009 | Saws
May 16, 2009 | Bosch #T101A3 3PK 4" 14TPI Jig Blade
How to change blade on bosch jigsaw GST 80 PBE
Hope that helps.
AG
Porsgrunn Norway
Dec 07, 2007 | Coffee Makers & Espresso Machines
Saws Logo
32 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
