Question about Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder
IR Blaster Code for DirecTV D12-300 Satellite Receiver
I bought a cheapo DirecTV Branded Satellite Receiver that does not have a serial port. I have an old PV-HS2000 Hard Disk Recorder I want to use. I tried all of the IR-Blaster codes in the PV-HS2000 setup and none seem to control the DirecTV Satellite Receiver. Does anybody know how I can control the Satellite receiver through my HS2000? I do not want to buy a TIVO, because the HS2000 allows me to pause a show for several hours, rather than just 15 minutes. (I also don't want to pay for a service.) Any suggestions appreciated.
  • mfabo Sep 30, 2007
    After multiple failed attempts to find an IR code, I contacted DirecTv and had them send me a new card for an old Sony Receiver I located. I got the card yesterday, hooked up that receiver w/serial port, and am in business. I am concerned about what to do when this Sony receiver dies.
    Is there another DVR out there that allows you to pause a show for as long as there is disk space? The 15-30 minute pause TIVO offers is unacceptable to me. It is clear that there are many codes out there and not all are available in the HS2000. I like the HS2000 because it:
    Doesn't cost for a monthly service
    Allows me to pause for several hours
    Thanks for the response.
  • 150 Answers
After digging around for awhile, the only onfo I could gather was that teh D12 uses the same codes as the D10 & D11, but could not get those codes, I am still looking around and will post any other info I may aquire. I would also suggest re-trying any codes for echostar. I can tell you this as I sell that equipment in my market and echostar provides the equipment and support for techs, installers, and retailers. Anyway Good Luck for now
Posted on Sep 30, 2007
SOURCE:
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
Emerson Jumbo Universal Remote won't program Direct TV receiver.
Have you tried doing this:
Press and hold the TV button on the remote till all 4 buttons light up and flash(make sure your TV is on). Once they flash, press the power button, then using the channel up button, point the remote at the TV and keep pressing it till the TV turns off. When it does, press the # sign and that will lock in the new found code.
Hope that helps........
Jul 21, 2008 | Televison & Video
Can i program lg magic remote to work with direct tv box
If your LG TV came with the IR blaster cable you will need to set one of the sensors in front of the sensor on your DirecTV box. Then go to your TV setting and select Video Input and Select the Input Port that your DirecTV box is hooked to. (In my case HDMI1). Then you will select that you are trying to sync your Service Provider and it will give you a list of device manufacturers. Select DirecTV limited and it will start to give you codes to try. You test these by trying the channel button up or down. If the channel changes you have found your code and you will click on "Yes" and you are ready to control. The "Guide" button will now bring up the DirecTV Guide and you no longer need the DirecTV remote.
Jun 05, 2012 | LG Televison & Video
How do i hook my direct tv to the philips tv
This is what you'll need to do this:
  • Your DirecTV receiver, DirecTV access card, and your DirecTV satellite dish.
Step 1: You need to write down the serial number that is on your DirecTV access card onto a piece of paper that you will need for future reference. You'll need the number to activate your service with the DirecTV company. Now take your access card and insert it into your box, there is a slot either on the back or front side in which the card with enter.
Step 2: Plug the cable line that is coming from your satellite dish into the "Satellite In" plug on the back of your receiver box.
Step 3: Look for the "Out to TV" port on the back of your receiver, and use the proper cable, which should come with it, to plug it from the receiver into the proper port in the back of your TV.
Step 4: Power up the receiver and your TV (after plugging in the power cable and all) and tune into either channel 3 or 4, depending on where you live.
Step 4.5: You may be prompted to plug in a phone line, in which case you would need to plug in a phone cable into the back of the receiver, but this is only required as a one time thing, you may unplug it after activating your account.
Step 5: Once everything is set up (which it should be at this step), call DirecTV at 1-800-531-5000 to activate your access card, and you will need to use the serial code you copied down from it.
Step 6: After your access card is activated, enjoy watching on DirecTV!
Jan 03, 2011 | Philips Televison & Video
I have a hr21-700 and bought a universal remote (logitech harmony 900) and the unit will not respond to rf commands? I went throught the setup process in the menu option, help
The DVR must be set to use IR instead of RF. The RF Blaster that comes with the remote converts the RF from the Harmony remote to IR commands.
Dec 29, 2010 | Directv HR21-700 DTV Receiver
Toshiba dr-2 and directv hd sat rcvr hr22
Check the manual to see if there is an automatic code search feature for your Toshiba. It may be easier to program your directv remote to operate your toshiba. You may not get the full use from either remote, but its worth a shot
Dec 01, 2008 | Arris DCT2608
Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Feb 05, 2008 | RCA DRD430RG DirecTV DTV Receiver
DirecTV RC64R RF Remote control
Actually, you can go into the system settings by choosing "Parental, Fav's & Setup" then choose "system setup" then choose "remote" the IR/RF setup. Change it to IR and follow the instructions. Once I did that my remote worked on my DirecTV DVD HR22-100
Nov 28, 2007 | RCA DRD480RE Receiver
Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder Logo
637 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
