Question about Hoover Elite Rewind Bagless Upright VacuumVacuum
Hoover UH30010 shuts off every 3 seconds - Hoover Elite Rewind Bagless Upright VacuumVacuum
    Sergeant:
    Champion:
  • Hoover Expert
  • 357 Answers
Stopped up most likely
Posted on Oct 21, 2013
Uh30010. Why does it start and stop continually?
Have the same issue. Ever find out why??
Oct 28, 2015 | Hoover Vacuums
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
When I turn it on it shuts down in about 3 seconds, bag is empty, no blockages?
Sounds like a bad handle assembly. Unfortunately these are known for being quirky when the circuit board goes bad. There's nothing else to go wrong with the rest of the unit. Here's the part and number. Good Luck
http://vacuummedic.com/product.php?id=389
Apr 20, 2013 | Hoover UH30010COM Bagged Vacuum
I have uh30010 hoover that stops and flashes when handle tilted
I had one in doing this last week. I replaced the upper handle and it acted normally again. Maybe just a bad connection where the handle plugs in?
This is the part I'm speaking of:
http://www.vacuummedic.com/product.php?id=389
Good Luck
Feb 11, 2013 | Hoover UH30010COM Bagged Vacuum
I replaced the handle on my Hoover UH30010 Platinum Bagged upright and now the check bag light is on and vac will nut run.. Is there a reset button? How do I fix this?
Hey. I believe you will need to replace the main PCB board too. My new handle was sent with a new PCB board. However, I tried just replacing the handle first and it acted the same way you describe. Once I changed the PCB board it worked fine. Hope this helps.
May 25, 2012 | Hoover Ultra U6430-900 WindTunnel Bagged...
I have a Hoover Wind Tunnel bagless mach 4.7 vacuum that shuts off after about 30 seconds. I suspect it is overheating, but there are no clogged lines. The on/off switch is in good working order. Help!!
is your filter clean? you should be able to see the pleats in the filter pretty clearly. also the metal screen that is next to the filter should be clean as well. if the problem continues it could be a faulty thermal protector ( a device that shuts the machine of when it over heats. )
Sep 17, 2008 | Hoover Vacuums
Hoover Sensory 2200W Overheating and Shut-Down
Did you ever get to the bottom of your overheating and shut-down problem? Just got the same problem :(
regards,
Mar 31, 2008 | Hoover Vacuums
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
Hoover Elite Rewind Bagless Upright VacuumVacuum Logo
126 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
