Question about Dishwashers
How to install a sink drain line - Dishwashers
  • 5,245 Answers
Copy following link with some illustrations of tubular plumbing installation:
http://waterheatertimer.org/How-to-install-vent-under-sink.html
Otherwise add a comment with more detail about what you are doing
Gene
h
Posted on Oct 18, 2013
What would cause a gurgling sound at the kitchen sink when no water is running anywhere in the house?
the waste disposal system for your house was installed by a person who was not competent to do the job and didn't make allowances for sufficient air pipes in the system or placed them on the wrong side of the traps
I would have an engineer inspect the installation to pin point the problem so that what you have doesn't occur and if it is installed contrary to plan and engineering requirements seek legal redress from the plumber that did the job
Nov 15, 2015 | Dishwashers
My newly installed dishwasher won't drain.
The check valve may have been installed backwards.
Jan 04, 2015 | Dishwashers
Connectingit hooking it up
The exact list of parts for a dishwasher hook-up would depend on the existing plumbing and electrical . There are three hook-ups needed; a hot water feed, typically from under the sink. A Tee is installed on the hot water line with a valve, and the hot water line to the dishwasher is connected to the valve. A drain line from the dishwasher is installed under the sink. It connects to the sink drain. The Electrical connection can be made using the appropriate electrical cord.
There are specific guidelines and considerations on how to connect the drain line under the sink, and what is required for the electrical hook-up. If you do a search on "how to install a dishwasher" you will be able to find extensive information.
2q== 9k=
Apr 10, 2014 | Dishwashers
Maytag dishwasher won't drain
Drainage problem of some sort is usually the cause. Could be blockage before your drain pump, in your drain pump, or in your drain hose. One possibility is that you just installed a garbage disposal and forgot to remove the "knock-out" plug for the dishwasher drain line. Another cause can be that you have not looped your dishwasher drainline under your sink and water from your sink is flowing back into you dishwasher. You must attach your dishwasher drain line under your sink so it is higher then your sink drain lines, creating a trap for your dishwasher. Your drain sump could be plugged, not letting the water get to your drain pump easily. This is caused by not getting loose or hard debris off your dishes before putting them in the unit. Also make sure your drain pump is getting the right voltage when it is supposed to.God bless youfa618d8b-d0fd-412a-b0d5-a88d44bf89d3.giffb1320dc-7bec-4cb0-98ed-c24cf54e5e3b.jpg
Apr 02, 2013 | Dishwashers
Newer Maytag dishwasher smells really bad inside
This problem can normally be fixed very simply and you can do it yourself.
1. There is a flexible drain line that goes from dishwasher to the sink drain line or garbage disposer.
2 You will find this flexible drain underneath the kitchen sink.
3. Make sure that the flexible dishwasher drain line goes up above the sinks lower portion of the sink basin and then comes back down into the sinks drain line or grabage disposer. The dishwasher flexible drain line must go above the bottom of sink basin like an upside down u shape, it will act as a upside down p-trap that you see under the sink in the sink drainline.
4. Once you have the flexible dishwasher drain line in this configuration (upside down U shape or p-trap) it will prevent air from leaking out of the dishwasher as the smell you are smelling is coming from the drian line.
5. You should also look inside the bottom of dishwasherr to make sure the drain screen is not clogged up.
Sep 08, 2011 | Dishwashers
Bad smell coming from bottom - water doesn't completely drain out
Make sure the drain hose is not blocked or pinched.Also check where it drains into your sink pipeing to be sure food isnt blocking the drain way.
Its eather the drainage path is blocked or the pump stoped pumping.
Also, the drain hose must be installed so as to have a high spot higher than the sink drain or the water from your sink will be able to "run down hill" or drain into your dishwasher. Take a look and see!
also It sounds like your dishwasher does not have an air gap. Newer dishwashers come with an air gap installed, but they can be taken out. A quick fix for this is to:
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher, and garbage disposal.
Aug 17, 2010 | Bosch Dishwashers
Ge dishwasher water backs in when not running after it is empty? Water line to drain is connect to garbage disposel. if i still have problem would like phone to talk to someone thanks
You need to install an air-break to prevent dirty water from entering into the dishwasher.
These are typically installed on the flange of the sink and provides a positive break in the drain line from the dishwasher going into the disposal drain port, thus preventing back flow.
You can get these at any big box or hardware store in the plumbing section. Normaly, these are easy to install with some basic tools, unless you have stone countertops and an undermount sink. In that case, you'll need to install the air gap fixture under the countertop at the highest point possible, unless you want to go to the trouble and expense of having a custom hole cut into the countertop (both costly and not very attractive either).
With an air gap connector (back-flow preventer) installed on the drain line, you'll no longer have sink water able to flow into the dishwasher.
If this was a new dishwasher installation done by a paid professional, you need to contact them, as they did NOT do it properly and violated universal plumbing code by not installing an air gap on the dishwasher drain/discharge line.
If is was a self installation, you should read the installation instructions that came with the dishwasher, as it specificially addresses this issue. If a buddy helped, you might want to find a smarter buddy (kidding). If pre-existing condition, you ncan resolve the problem as I've described above with a little time and not much cost for the parts needed.
Hope you find this Very Helpful and best regards!
Aug 19, 2009 | Dishwashers
I INSTALLED A VENT IN MY SINKTOP FOR THE WASHER AND WHEN IT DISCHARGES THE WATER IT COMES OUT THE VENT AND RUNS INTO THE SINK.
Installed vent? Dishwashers drain directly into the sink drain line. Drain can be installed in cross over between sink drains or on line from sink drain.
Jun 22, 2009 | Frigidaire FDB1502RG Built-in Dishwasher
HOTPOINT 3400 DOES NOT DRAIN totally
Hi Bob,
Yeah! I'm a Texan! Cool!
I'd almost bet that your dishwasher drain line is NOT clogged but simply installed incorrectly. If I'm right, some water from the sink will drain (siphon) back to your dishwasher making you believe that it's not draining properly. (BTW, I've had a thousand service calls run for just this problem, so I know of what I speak)
Look under your sink and take a gander at your dishwasher drain line... if it looks like this, it ain't right.
This allows sink/disposal water to siphon off to your DW. All you gotta do is loosen the clamp (in the pic), remove the drain line, pull as much slack as you can (without pulling to hard... like it'll break if you do that) and put a loop in it like this...
OK... after you get your loop, you'll need to tighten your hose clamp. As an extra measure of security (to keep the loop in place), secure the drain hose to your sinks water supply line.
There ya go! 15 minutes, no parts, no head-aches and you're done! Cool, huh? All you gotta do now is kick back and wait for the Cowboys pre-season! (BTW... if your drain is installed properly, write back and we'll go a little deeper into a diagnosis, OK?)
SG
May 17, 2009 | Hotpoint 24 in. HDA3400G Built-in...
How to install diswasher
To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
#1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
#2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
#3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
#4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
x 3/8" compression ell at the dishwasher.
#5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
#6 Install a 6' pigtail power cord to the power box under your dishwasher.
#7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
#8 Attach the water line to the open connection on the double stop.
#9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
#11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
#12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
#13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
#14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
#15 Attach the bottom kick panels
You are done.
If you have any questions, please let me know.
Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
