While microsoft office 2007 was installing a window appeared and said setup cannot find Publisher.en-us/PubLR.cab. Browse to a valid instalation source, and then click ok. i tried every thing and cant get it to work.
That particular file cabinet that you really should find on a properly registered version of Microsoft Office for English in the US as a registration number will be necessary to fully install Office.
Call Microsoft, and tell them that it's not there, though it should be.
Supply them your C(ertificate O(f) A(uthencity) and you should be good to go.
Do you have at least a 2.0 GHz processor (you can see this in windows xp by going to your start menu, click control panel, then performance and maintenance, then just click system. in the general tab, it will show you your processor's speed which MUST be atleast 2.0 GHz to install microsoft office 2007)
you can also get a lower version of microsoft office (i mean like office 2003 or something like that)
First, uninstall the trial. Verify you cannot uninstall Trial 2007Microsoft Office system using Add/Remove Programs or Programsand Features. To verify cannot uninstall the 2007 Microsoft Office system by using Add or Remove Programs (Programs and Features Windows Vista). Windows XP or Windows Server 2003 Click Start, click Run, type control appwiz.cpl in the Open box, press ENTER. Select the 2007 Office system product from application list, click Remove. Windows Vista Click Start, type programs and features in the Search box, and then press ENTER. Select the product to be uninstalled from the list of installed products,click Uninstall/Change from the bar that displays available tasks. If able to uninstall the 2007 Microsoft Office system by using Add or Remove Programs, you are finished.If unable to uninstall the 2007 Microsoft Office you may have issues with the Add or Remove Programs dialog box, or 2007 Microsoft Office components may not be uninstalled. In these cases, you may be unable to reinstall the 2007 Microsoft Office . However there is an alternative method. Use this method only if the Add or Remove Programs method did not work for you. Using this method does not completely uninstall the 2007 Microsoft Office. After you use this method, you can reinstall the 2007 Microsoft Office .there is an alternative method. and you can always ask me if this isn't enough info. get you going. good luck please rate me
If Add or Remove Programs does not uninstall the 2007 MS Office alternative method to uninstall Use this method only if the Add or Remove Programsmethod did not work for you. After you use this method, you can reinstall the 2007 Microsoft Office.You must be logged on to Windows as a computer administrator to complete. Remove any remaining Windows Installer packages of the 2007 MS Office.Click Start, click Run, type installer, and then click OK. This process opens the %windir%Installer folder. On the View menu, click Details.Windows Vista, you must press the ALT key first to display the menu bar, and then click the View menu.Choose Details select the Subject check box, type 340 in the Width of selected column (in pixels) box click OK. XP or Server 2003 View menu, point to Arrange icons by, and then click Subject. Vista View menu, point to Sort By click Subject. Vista User Account Control dialog box An unidentified program wants access to your computer Click Allow For each .msi file where the subject is "MS Office Product_Name 2007," right-click the .msi file, and then click Uninstall Stop the Office Source Engine service XP and Server 2003 click Start, click Run, type services.msc in Open box click OK. Vista Start, click Start Search, type services.msc, and then press ENTER. In Services , determine whether the Office Source Engine service is running. If it is right-click Office Source Engine, and then click Stop Close the Services window Remove any remaining 2007 MS Office installation folders XP and server 2003 click Start, click Run, type %CommonProgramFiles%Microsoft Shared in the Open box, and then click OK. Vista Start, click Start Search, type %CommonProgramFiles%Microsoft Shared, and press ENTER 64-bit version of Windows Vista, type %CommonProgramFiles(x86)%Microsoft Shared, and then press ENTER If the following folders are present, delete them Office12 Source Engine XP and server 2003 Start, click Run, type %ProgramFiles%Microsoft Office, and then click OK 64-bit version of Windows XP, type %ProgramFiles(x86)%Microsoft Office, and then press ENTER. Vista Start, click Start Search, type %ProgramFiles%Microsoft Office press ENTER 64-bit Windows Vista, type %ProgramFiles(x86)%Microsoft Office press ENTER. On the root folder of each hard disk drive, locate and then open the MSOCache folder. If u cannot see the MSOCache folder Open Windows Explorer, and then on the Tools menu click Folder Options Click the View tab Advanced settings Hidden files and folders, click Show hidden files and folders.Click clear the Hide protected operating system files check box then OK. Open the drive_letter:MSOCacheAll Users folder, and then delete every folder that has the following text in the folder name 0FF1CE)- This text contains a zero and a one for the letters "O" and "I. Remove any remaining 2007 Microsoft Office installation files XP and Server 2003 Start, click Run, type %appdata%microsoft emplates, and then click OK. Vista Start, click Start Search, type %appdata%microsoft emplates press ENTER. Delete the following files Normal.dotm Normalemail.dotm XP and server 2003 Start, click Run, type %appdata%microsoftdocument building blocksLanguage_ID click OK. Vista Start, click Start Search, type %appdata%microsoftdocument building blocksLanguage ID press Enter
If you cannot open this folder because the folder does not exist,Restart computer
Language_IDis a placeholder for the four-digit number that represents the languageof the 2007 Microsoft Office system. For example, if you use theEnglish version of the 2007 Microsoft Office system, the Language_IDvalue is 1033. If the Language_ID is not known, type %appdata%microsoftdocument building blocks, and then open the subfolder in that location.
Delete the Building blocks.dotx file.
For Windows XP and Windows Server 2003, click Start, click Run, type %temp%, and then click OK.
For Windows Vista, click Start, click Start Search, type %temp%, and then press ENTER.
On the Edit menu, click Select All.
On the File menu, click Delete.
For Windows XP and Windows Server 2003, click Start, click Run, type %AllUsersprofile%Application DataMicrosoftOfficeData, and then click OK.
For Windows Vista, click Startclick Start Search, type %AllUsersprofile%Application DataMicrosoftOfficeData, and then press ENTER.
Delete only the Opa12.dat file. Remove the registry subkeys 2007 Microsoft Office
Locate and then delete the registry subkeys of the 2007 MicrosoftOffice system if they are present. To do this, follow these steps:
For Windows XP and Windows Server 2003, click Start, click Run, type regedit, and then click OK.
, click Start Search, type regedit, and then click OK. Click the following subkey: HKEY_CURRENT_USERSoftwareMicrosoftOffice
.0On the File menu, click Export, type DeletedKey01, and then click Save.
On the Edit menu, click Delete, and then click Yes to confirm the deletion.
Foreach registry subkey in the following list, repeat steps 1a through 1d.Change the name of the exported key by one for each subkey.
For example, type DeletedKey02 for the second key, type DeletedKey03 for the third key, and so on.
32-bit versions of Microsoft Windows:
64-bit versions of Microsoft Windows: HKEY_CURRENT_USERSoftwareMicrosoftOffice
.0 HKEY_LOCAL_MACHINESOFTWAREMicrosoftOffice
.0 HKEY_LOCAL_MACHINESOFTWAREMicrosoftOfficeDeliverySourceEngineDownloads*0FF1CE}-*
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionUninstall*0FF1CE*
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionInstallerUpgradeCodes*F01FEC
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionInstallerUserDataS-1-5-18Products*F01FEC
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetServicesose
HKEY_CLASSES_ROOTInstallerFeatures*F01FEC
HKEY_CLASSES_ROOTInstallerProducts*F01FEC
HKEY_CLASSES_ROOTInstallerUpgradeCodes*F01FEC
HKEY_CLASSES_ROOTInstallerWin32Assemblies*Office12*
.0 HKEY_LOCAL_MACHINESOFTWAREWow6432NodeMicrosoftOffice
.0 HKEY_LOCAL_MACHINESOFTWAREWow6432NodeMicrosoftOfficeDeliverySourceEngineDownloads*0FF1CE}-*
HKEY_LOCAL_MACHINESOFTWAREWow6432NodeMicrosoftWindowsCurrentVersionUninstall*0FF1CE*
HKEY_LOCAL_MACHINESOFTWAREWow6432NodeMicrosoftWindowsCurrentVersionInstallerUpgradeCodes*F01FEC
HKEY_LOCAL_MACHINESOFTWAREWow6432NodeMicrosoftWindowsCurrentVersionInstallerUserDataS-1-5-18Products*F01FEC
Locate the following registry subkey: HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionUninstall Note On a computer that is running a 64-bit version of Windows, locate the following registry subkey instead: HKEY_LOCAL_MACHINESOFTWAREWow6432NodeMicrosoftWindowsCurrentVersionUninstall
On the File menu, click Export, type UninstallKey01, and then click Save.
Underthe Uninstall subkey that you located in step 2, click each subkey, andthen determine whether the subkey has the following value assigned toit:
Data: file_name pathOffice Setup ControllerSetup.exe path
In this example, file_name is a placeholder for the name of an installation program, and path is a placeholder for the file path.
If the subkey contains the name and the data that are described in step 4, click Delete on the Edit menu. Otherwise, go to step 4.
Repeatsteps 4 and 5 until you locate and then delete every subkey thatmatches the name and the data that are described in step 4.
Close Registry Editor. Restart the computer. If the uninstall was successful, you are finishedand can now reinstall the 2007 Microsoft Office system if you want If the uninstall was not successful, go to the "Next Steps" section
Additional registry UserInfo subkeys:HKEY_CURRENT_USERSoftwareMicrosoftOfficeCommonUserInfoShadow subkeys for Windows Server 2003 and for earlier versions of Windows Server:HKEY_LOCAL_MACHINESoftwareMicrosoftWindows NTCurrentVersionTerminal ServerInstallSoftwareMicrosoftOffice
.0Shadow subkeys for Windows Server 2008:HKEY_LOCAL_MACHINESoftwareMicrosoftWindows NTCurrentVersionTerminal ServerInstallSoftware
when i start installation , the installation procces starts after some time it ask for a file but i have no file
Have you had the trial version installed? Did you uninstall it before you tried to install the paid version? Have you searched your cd or your hard drive for that file?
