Question about Radio Communications
Plantronics problems MY HEADSET IS BUZZING IF WHEN THE SET IS TURNED OFF
3 Suggested Answers
  • 32 Answers
SOURCE: Plantronics headset crapped out after black out
The black out or power surge could have affected the unit and caused it to short circuit.  If you have purchased it within 1 year of today's date, it is still under warranty and can be replaced by plantronics.
Posted on Apr 28, 2009
HDI Headsets
  • 537 Answers
SOURCE: plantronics 330 bluetooth headset / Nextel Blackberry 7100i performance
After looking through the phones, there many possibilities, wow quite a few. It does not have any recommendations on headsets. The headset is only as good as the the quality you are purchasing. If your phone drops calls it won't be from the bluetooth device. Below is a link to the Explorer Series 300 User's Guide, which may help you.
Plantronics Explorer Series 300 User's Guide
Good luck from Headsets Direct!
Posted on Dec 14, 2011
Plantronics Explorer 320 I can hear but nobody can hear me
ok..try to go your sound settings, maybe the microphone is turned off. OR try to restart your phone just to make that headset is working properly.
Jan 22, 2008 | Plantronics Explorer 320 Wireless Headset
Need to pair my nokia5310 to plantronics explorer 210
You don't mention if this is your first time pairing the headset, you will need to turn on your blue tooth on your cell phone, the light on the headset should come on flashing red/blue. If it does not refer to sub pairing instructions below. The cell phone should find the headset. 2XX Plantronics in your list. If the pass key is needed it is (four zeros). Second time pairing or more than one device, turn on bluetooth feature, headset turned on, press and hold the call button for about 5-6 seconds. Release button and set headset aside. On cell phone hit bluetooth menu, search for add device. The cell phone should find the headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 17, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
My headset has a constant buzzing in earpiece. Even when no line is selected. Can't hear dial tone.
On left hand side of base unit dial has to be set with the number 1 in the 3'oclock position. On the right hand side of base unit there is a switch set it to the 1 position. On the headset press and hold the vol - and vol + and pick up call buttons at the same time until an orange light on headset blinks a few times.
Problem solved
Jan 04, 2010 | Plantronics Radio Communications
PLANTRONICS VHB 300 PURPLE LIGHT
HI
I SOLVED THE PROBLEM
LET THE HEADSET RUN DOWN, THEN PUT IT ON CHARGE,RED CHARGING LIGHT CAME ,CHARGED FOR 2 HOURS, THEN PAIRED TO 6300, WORKING OK.
JOHN
Sep 06, 2008 | Plantronics Explorer 320 Wireless Headset
220 Plantronics stopped working
Look under my name and find the previous 10-20 posts helping others with similar problems on adding/removing the existing connected device. However the Plantronics 220 Express and regular have connection problems with phones if they are far away, and sometimes get corrupt, unfortunately, for a $28.00 headset, its build for $28.00 of use.
Please review my previous posts and see if this can help you at all..
ManOwar
Aug 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Can't connect to Cell.
I am helpconnect from above problem. I finally got my 320 plantronics wireless headset to connect. I did not have problems pairing my headset, but it would not connect. I had removed and added back the device several times with no luck. Then, I turned my phone and headset off for approx. two minutes and turned them both back on and selected the yes to connect and it did.
Jul 25, 2007 | Plantronics Explorer 320 Wireless Headset
How to set my bluetooth up on my cell phone
Go to: http://www.plantronics.com/media/media_resources/literature/user_guides/explorer300series_nasa.pdf
May 04, 2007 | Plantronics Explorer 320 Wireless Headset
Radio Communications Logo
15 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
